Confirm VPN L2L return routing understanding?
MicJameson1
Hello.
May you please confirm my understanding?...
GIVEN: an ASA5525 has a site-to-site
VPN erected. The remote vendor subnet defined in this local ASA
route-map ACL is 172.16.0.1
The Inside interface of this local ASA is
192.168.0.1/24
A local LAN server 10.0.0.1 has successful EIGRP communication with the above local ASA through
192.168.0.1/24
and also an adjacent EIGRP routing L-3 switch.
QUESTIONS:
1. Is it true that in order for the 10.0.0.1 server to send return traffic back to remote vendor tunneled subnet, there must be configured a return route; for example, an EIGRP
redistributed static route ip route 172.16.0.1 255.255.255.255 192.168.0.1 ?
2. If this above static
redistributed route
lives on the adjacent L-3 switch, and the ASA receives the EIGRP
redistributed routes
must the ASA have any additional routing configured on its configuration for the remote server to have successful return traffic communication, such as a static route to the remote server (or does the
route-map
ACL handle this final routing activity?)?
Thank you.
Hello @MicJameson1 ,
>> Is it true that the
Crypto map
only needs the subnets of the ENDPOINT server subnets, NOT any other subnets in between?
Yes, your understanding is correct the
crypto map
specifies only the local and remote subnets that need to communicate over the IPSEC site to site tunnel.
The local subnets can be directly connected to the VPN termination device or they can be behind one ore more L3 devices. The topology of the site is not important. What is needed is to specify local subnets  and remote subnets as they become the criteria for encryption of tx traffic and of decryption of received encrypted packets.
Hope to help
Giuseppe
Giuseppe Larosa
1)  a
default route
pointing to ASA LAN interface on the L3 switch is enough.
To be noted if you want to enable communication between
10.0.0.0/24 and remote 172.16.0.0/24
you need to edit the ACL used in the
crypto map
that has to provide all the possible combinations of local subnets and remote subnets.
The remote site ACL has to be a mirror of the local one with all combinations of remote subnets to local subnets.
2)   if using a
default route
on the L3 switch as described above the
crypto map
policy will
route/encrypt
packets to remote destination
172.16.0.0/24
To be noted an ASA firewall by default would perfrom NAT between interfaces for the VPN traffic to work NAT exemption or specific NAT rules (identity NAT) have to be configured to avoid this.
Hope to help
Giuseppe
Thank you for your reply, Giuseppe.
"the
crypto map
that has to provide all the possible combinations of local subnets and remote subnets. The remote site ACL has to be a mirror of the local one with all combinations of remote subnets to local subnets."
-- Is it true that the
Crypto map
>> Is it true that the
Crypto map
crypto map
Hope to help
Giuseppe
