Connect Cisco 1941 to ZTE ZXHN H108N for internet access
Yashas Sridat
Hello guys,
I am trying to connect a cisco 1941 to a ZTE ISP modem (Mauritius Telecom) as on the 1941 I dont have a WIC 1B-S/T-V3 to support ADSL connection (( btw its on the way bought it from ebay :) )) I cannot connect to the internet :(
From the ZTE modem there are four FE ports
and the Def-Gateway for the modem is 20.20.20.1
1. ZTE Port FE1 is connected to Cisco1941 G0/0 (ip nat outside | ip address DHCP)
2. Cisco1941 G0/1 connected to a Cisco 2950 SW Fa0/24 (RT can ping SW Vice Versa)
3. Cisco1941 has 4 sub interfaces G0/1.1 - 4 (Encap dot1q)
I dont know what's wrong in my conf or i missed something.
Here is the conf fot the ZTE interface, dhcp etc...
and the modem zte can learn the mac of devices connected to it
here is static route that I ve made on the zte and still it doesnt work, even if I remove it.
do not consider the network 10.10.10.xxx gateway as it was corrected
and here is the Cisco 1941 conf
Current configuration : 2834 bytes
! Last configuration change at 09:35:54 UTC Sun Mar 27 2016
version 15.1
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 !"£$%"^&(!(*&^"%^&*"()!(*&^%"$
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.10.10.1 10.10.10.30
ip dhcp excluded-address 10.10.20.1 10.10.20.30
ip dhcp excluded-address 10.10.30.1 10.10.30.30
ip dhcp pool WIFI
import all
network 10.10.20.0 255.255.255.0
default-router 10.10.20.1
dns-server 8.8.8.8
ip dhcp pool CCTV
import all
network 10.10.30.0 255.255.255.0
default-router 10.10.30.1
dns-server 8.8.8.8
ip dhcp pool Management
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 8.8.8.8
ip dhcp pool IP_MGMT
import all
network 20.20.20.0 255.255.255.0
default-router 20.20.20.1
dns-server 8.8.8.8
ip domain name sysridat.com
license udi pid CISCO1941/K9 sn FGL154225HK
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed 100
interface GigabitEthernet0/1
no ip address
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1.1
description MGMT
encapsulation dot1Q 101
ip address 10.10.10.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.2
description WIFI_AP
encapsulation dot1Q 201
ip address 10.10.20.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.3
description CCTV_CAM
encapsulation dot1Q 301
ip address 10.10.30.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.4
description IP_MGMT
encapsulation dot1Q 200
ip address 20.20.20.1 255.255.255.0
ip nat inside
ip default-gateway 20.20.20.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
access-list 101 permit ip 10.10.20.0 0.0.0.255 any
access-list 101 permit ip 10.10.30.0 0.0.0.255 any
access-list 101 permit ip 20.20.20.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password xxx
login
transport input all
scheduler allocate 20000 1000
end
And this one for the Cisco 2950 SW
Current configuration : 1632 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
enable secret 5 !"£$%^&*()(*&^%$£$%^&HGVBNM"£$%^
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
vtp mode transparent
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan 101
name MGMT
vlan 200
name IP_MGMT
vlan 201
name WIFI_AP
vlan 301
name CCTV_CAM
interface FastEthernet0/1
switchport access vlan 200
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
switchport trunk allowed vlan 101,200,201,301
switchport mode trunk
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan101
no ip address
no ip route-cache
shutdown
interface Vlan200
ip address 20.20.20.3 255.255.255.0
no ip route-cache
ip http server
line con 0
line vty 0 4
password xxx
login
line vty 5 15
login
end
Hope to find someone to help me to sort out this problem.
Thanks in advance
0 Replies 0
