connect switch stack to fabric extenders
Tyco_Cisco
I need to connect switch stacks (3750G) to fabric extenders 2232PP.
switch stack contains two cisco 3750G. I want to connect 2 uplinks from each 3750G to fabric ext 1 and fabric ext 2.
I have tried to configure port-channels on 3750G. I have configured port-channel on 2232PP and vpc to link the ports on both switches.
2232PP -1
interface port-channel350
  switchport mode trunk
  switchport trunk allowed vlan 350
  speed 1000
  vpc 350
interface Ethernet154/1/31
  speed 1000
  channel-group 350 mode active
2232PP -2
  speed 1000
  vpc 350
  speed 1000
3750G-1
interface GigabitEthernet1/0/49
  channel-group 1 mode active
interface GigabitEthernet1/0/50
the ports go into errdisabled mode due to the bpduguard error. Can someone please advise how this setup can be configured.
disable bpduguard on the 3750G interfaces
"no spanning-tree bpduguard enable"
Thanks Richard for looking into this query. I had tried the above comment. But then it got disabled at the fabric extender end.
I don't know the fabric extender, I assume you need a similar to disable the bpduguard
