Connecting 2 VPN networks to core
Karl Breiner
Background: we have an existing VPN ("Provider VPN") that provides an mpls vpn to connect various 10.20.0.0/16 networks to our core router, a Cisco 3825.  The routing protocol the provider has in place is BGP, and the BGP routes to these remote networks can be found in our core.  We would like to create our own VPN networks ("Company VPN") that will be terminated at an ASA 5520, which will be connected to our core router.  We would like the 2 VPN networks to be connected, such that networks on the Company VPN can connect to the Provider VPN and vice versa.
Problem: how do I advertize the 10.60.0.0/16 networks to my core router?  It looks like the ASA does not support BGP. Do I need to use OSPF or RIP, and if so, how does BGP learn about them?
5 Replies 5
Jeff Van Houten
Level 5
Level 5
How about you just put In a static and redistribute that?
Ok, so I started doing this with static routes.  I now have this route in my core router
ip route 10.60.0.0 255.255.0.0 10.250.0.2 1
My LAN (directly attached to core router) can ping 10.60.0.0 network (and vice versa) but remote sites on 10.20.0.0/16 cannot.  If I trace route from a remote site it dies at my core router.  Does this route need to be redistributed to BGP? If so how?
Hello Karl,
Can you elaborate on your company's vpn connection, if possible port some config of the core and the Fw
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
I think this may be the relevant portion of the core router config.  Forgot to mention I actually have 2 routers in the core running HSRP.. that's what standby statements are.
I think Jeff Van Houten's idea is essentially what I need to do.. but it's just a little nerve-racking given the possibility of breaking BGP and the routes to all my external sites, or the possibility of creating an unanticipated routing loop.  I looked in my routing table and I have at least 10 static routes defined- mostly an accumulation of testing various things over the years, many of which were not put there by me.  I'm just concerned the 'redistribute static' command will bring over all these routes that I don't want into my provider VPN networks.  Any way to just single out the static route I mentioned above?  Maybe with a route-map?
Anyway, below is part of my core router config
interface GigabitEthernet0/0
description TO-FIOS
ip address x.x.x.x 255.255.255.0
ip virtual-reassembly max-reassemblies 64
ip route-cache policy
duplex auto
speed auto
media-type rj45
crypto map rtp
interface GigabitEthernet0/1
description Link to Linksys Switch port 2 / EIP Fiber
ip address 10.252.5.114 255.255.255.248
duplex auto
speed auto
media-type rj45
standby 200 ip 10.252.5.116
standby 200 priority 110
standby 200 preempt
interface FastEthernet0/1/0
switchport access vlan 9
spanning-tree portfast
interface FastEthernet0/1/1
switchport access vlan 100
interface FastEthernet0/1/2
switchport access vlan 6
interface FastEthernet0/1/3
switchport access vlan 250
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
interface FastEthernet0/3/0
description open
no ip address
duplex auto
speed auto
standby 2 ip 10.10.2.1
standby 2 priority 110
standby 2 preempt
standby 2 track 155 decrement 20
interface FastEthernet0/3/1
description INTERNET
ip address 10.10.1.3 255.255.255.248
ip helper-address 10.10.9.11
duplex auto
speed auto
standby 1 ip 10.10.1.1
standby 1 priority 110
standby 1 preempt
interface Vlan1
no ip address
interface Vlan6
description PRINTER
ip address 10.10.6.7 255.255.255.0
standby 6 ip 10.10.6.1
standby 6 priority 110
standby 6 preempt
interface Vlan9
description DATA
ip address 10.10.9.7 255.255.254.0
standby 9 ip 10.10.9.1
standby 9 priority 110
standby 9 preempt
interface Vlan100
ip address 10.100.10.7 255.255.254.0
standby 100 ip 10.100.10.1
standby 100 priority 110
standby 100 preempt
interface Vlan250
description NPVPN
ip address 10.250.0.2 255.255.255.248
standby 250 ip 10.250.0.1
standby 250 priority 110
standby 250 preempt
router bgp 65002
bgp log-neighbor-changes
neighbor 10.252.5.113 remote-as xxxxx
neighbor 10.252.5.113 password 7 12370000220E020A7E0E0D1870
neighbor 10.252.5.113 update-source GigabitEthernet0/1
address-family ipv4
  neighbor 10.252.5.113 activate
  neighbor 10.252.5.113 default-originate
  neighbor 10.252.5.113 soft-reconfiguration inbound
  neighbor 10.252.5.113 maximum-prefix 250
  no auto-summary
  no synchronization
exit-address-family
description TO-FIOS
duplex auto
speed auto
media-type rj45
crypto map rtp
duplex auto
speed auto
media-type rj45
standby 200 preempt
description open
no ip address
duplex auto
speed auto
standby 2 preempt
duplex auto
speed auto
standby 1 preempt
interface Vlan1
no ip address
interface Vlan6
description PRINTER
standby 6 preempt
interface Vlan9
description DATA
standby 9 preempt
interface Vlan100
standby 100 preempt
interface Vlan250
description NPVPN
standby 250 preempt
router bgp 65002
address-family ipv4
  no auto-summary
  no synchronization
exit-address-family
Ok, I did some research.  Anyone know if running these commands in my core will give me the route I need in BGP?
access-list 15 permit 10.60.0.0 0.0.255.255
route-map staticredist permit 10
match ip address 15
router bgp 65002
redistribute static route-map staticredist
