Connecting a cisco 1721 router to a Larcom unit
bfpnetworking
Monday, I had a cisco 1750 router in place suddenly stop communicating to a Larscom ISP owned unit.  Since then I have sent two replacement 1721 routers with WIC-1ENET cards.  I have used the original straight thru cable to connect the 10baset port on the Larscom to my E0 on the WIC-1ENET.  No link lights on either.  I have also tried a known working straight thru cable and a crossover cable.  No link lights.
I can take a crossover cable from a pc and ping the E0 port without issue.  The ISP is telling me it is an issue with my equipment.
Has anyone heard of this or have any ideas?
cadet alain
hi,
Can you try setting speed/duplex on e0.
Regards.
Alain.
