connecting a Cisco router to a cable modem
kevin.vannoy
I am having a problem I hope someone can help me with. I have a Cisco 2801 router with a 2950 switch. I have the switch configured with 3 VLANs and a trunk established in a router on a stick configuration. The VLANs function perfectly, but I do not have internet access at all. I configured fasteth0/0 to get its IP from the ISP via dhcp using the "IP address dhcp" command. I set up an access list and then enabled nat using that list. I issued the command "ip nat inside" on the interface with the switch attached. I issued the "ip nat outside" on the interface with the cable modem attached. The router is getting a public IP from the ISP and I configured DNS servers in global interface mode as well (8.8.8.8, 8.8.4.4). I have configured a static route via the interface connected to the modem as well. However, I am still not able to get connectivity. I am still learning and I would appreciate any help. Thanks so much!
11 Replies 11
michael o'nan
Level 4
Level 4
If you post your router config I can help you. Are you able to issue a command like ping 8.8.8.8 source fast 0/0.20 (or any of your subinterfaces)?
I can ping all of the sub interfaces on fa0/1, for the VLANs that I have configured on the switch. The devices on the VLANs can ping each other as well. I cannot ping the DNS server from anywhere for some reason. I am not home right now to access the routers configuration but I will post it later if that would help. Thanks for taking the time to answer my question. I appreciate it.
I understand you can ping internally but I was trying to judge if your NAT was setup correctly. If you can successfully ping an external IP from the router by using source of internal interface then NAT works. From your description it sounds like that is not the case. For any further assistance I would need to see the config.
Thank you Michael. I am posting the configuration now. I am still learning most of this so if you see something that could be done differently or that could be improved please let me know how to correct it. Again, thank you for the time and answers.
version 12.4
service password-encryption
hostname HomeRouter
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5
no aaa new-model
memory-size iomem 20
dot11 syslog
ip source-route
ip dhcp pool Internal
   import all
   network 192.168.10.0 255.255.255.0
   dns-server 8.8.8.8
ip cef
ip domain name HOME
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
voice-card 0
username Kevin privilege 15 password 7
archive
 log config
  hidekeys
ip ssh version 2
interface FastEthernet0/0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly
 no ip route-cache cef
 no ip route-cache
 duplex auto
 speed auto
 no cdp enable
interface FastEthernet0/1
 no ip address
 ip nat inside
 no ip route-cache
 duplex auto
 speed auto
interface FastEthernet0/1.1
 encapsulation dot1Q 10
 ip address 192.168.10.1 255.255.255.0
 ip nat inside
 no ip route-cache
 no cdp enable
interface FastEthernet0/1.2
 encapsulation dot1Q 20
 ip address 192.168.20.1 255.255.255.0
 ip nat inside
 no ip route-cache
 no cdp enable
interface FastEthernet0/1.3
 encapsulation dot1Q 95 native
 ip address 192.168.95.2 255.255.255.0
 ip nat inside
 no ip route-cache
 no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
no ip http server
no ip http secure-server
ip nat source list 50 interface FastEthernet0/1.1 overload
ip nat source list 51 interface FastEthernet0/1.2 overload
ip nat source list 52 interface FastEthernet0/1.3 overload
ip nat inside source list 50 interface FastEthernet0/1 overload
ip nat inside source list 51 interface FastEthernet0/1 overload
ip nat inside source list 52 interface FastEthernet0/1 overload
access-list 50 permit 192.168.10.0 0.0.0.255
access-list 51 permit 192.168.20.0 0.0.0.255
access-list 52 permit 192.168.95.0 0.0.0.255
control-plane
line con 0
 exec-timeout 0 0
 password 7
 logging synchronous
 login
line aux 0
line vty 0 4
 exec-timeout 5 55
 logging synchronous
 login local
 transport input ssh
line vty 5 15
 exec-timeout 5 55
 logging synchronous
 login local
 transport input ssh
scheduler allocate 20000 1000
end
You should be able to past that in to the CLI as is. I added comments after some things so you know why I did it. If you have any questions or would like more explanation just let me know.
   import all
   dns-server 8.8.8.8 8.8.4.4 !(added 8.8.4.4 for secondary DNS on client DHCP)
no ip name-server 8.8.8.8 !(this is name resolution on the router)
no ip name-server 8.8.4.4 !(this is name resolution on the router)
no ip domain-lookup
no ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 !Since your interface is DHCP it will learn default route automatically
no ip nat source list 50 interface FastEthernet0/1.1 overload
no ip nat source list 51 interface FastEthernet0/1.2 overload
no ip nat source list 52 interface FastEthernet0/1.3 overload
no ip nat inside source list 50 interface FastEthernet0/1 overload
no ip nat inside source list 51 interface FastEthernet0/1 overload
no ip nat inside source list 52 interface FastEthernet0/1 overload
ip nat inside source list NAT interface FastEthernet0/0 overload !NAT overload should be done on the ISP facing interface
ip access-list standard NAT
no access-list 50 permit 192.168.10.0 0.0.0.255
no access-list 51 permit 192.168.20.0 0.0.0.255
no access-list 52 permit 192.168.95.0 0.0.0.255
end
Hey Michael,
    Thank you very much for your assistance. Following the changes you posted I can ping addresses out on the internet from the router. However, I still do not have connectivity to my PC or any other device inside the network. I will post my router configuration again for you to review if you don't mind. Thanks again for the help.
version 12.4
hostname HomeRouter
boot-start-marker
boot-end-marker
enable secret 5
no aaa new-model
dot11 syslog
ip source-route
   import all
ip cef
ip domain name Home
no ipv6 cef
voice-card 0
archive
 log config
  hidekeys
ip ssh version 2
 ip address dhcp
 ip nat outside
 no ip route-cache
 duplex auto
 speed auto
 no cdp enable
 no ip address
 ip nat inside
 no ip route-cache
 duplex auto
 speed auto
 ip nat inside
 no ip route-cache
 no cdp enable
 ip nat inside
 no ip route-cache
 no cdp enable
 ip nat inside
 no ip route-cache
 no cdp enable
no ip http server
control-plane
line con 0
 exec-timeout 0 0
 password 7
 logging synchronous
 login
line aux 0
line vty 0 4
 exec-timeout 5 55
 logging synchronous
 login local
 transport input ssh
line vty 5 15
 exec-timeout 5 55
 logging synchronous
 login local
 transport input ssh
end
What kind of switch are you connecting to? If it is a Catalyst model please post the config.
Michael,
    The switch is a Catalyst 2950. Thanks again for the help. The configuration is as follows:
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname HomeNetwork
enable secret 5
ip subnet-zero
no ip domain-lookup
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
 switchport access vlan 10
 switchport mode access
interface FastEthernet0/2
 switchport access vlan 20
interface FastEthernet0/3
 shutdown
interface FastEthernet0/4
 shutdown
interface FastEthernet0/5
 shutdown
interface FastEthernet0/6
 shutdown
interface FastEthernet0/7
 shutdown
interface FastEthernet0/8
 shutdown
interface FastEthernet0/9
 shutdown
interface FastEthernet0/10
 switchport access vlan 95
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
 switchport trunk native vlan 95
 switchport trunk allowed vlan 10,20,95
 switchport mode trunk
interface FastEthernet0/25
interface FastEthernet0/26
interface Vlan1
 no ip address
 no ip route-cache
 shutdown
interface Vlan95
 ip address 192.168.95.1 255.255.255.0
 no ip route-cache
ip http server
line con 0
 exec-timeout 5 55
 password 7
 logging synchronous
 login
line vty 0 4
 exec-timeout 5 55
 password 7
 logging synchronous
 login
line vty 5 15
 exec-timeout 5 55
 password 7
 logging synchronous
 login
end
What port or VLAN are your devices using? Looks like FastEthernet0/1 would be the only port allowed to pull DHCP. Also just noticed you are missing this from your DHCP config:
 default-router 192.168.10.1
My desktop is on VLAN 10 at the moment. It is able to pull DHCP. The devices on the other VLANs I have configured with static addresses. How do I set it up to pull IP addresses from DHCP for all VLANs? I will try adding the default router command as well. That was an excellent observation. Again, thank you very much for your help. It is very much appreciated. Have a great day.
Since they are in different VLANs you will want them in different subnets as well. You just add a DHCP pool for this.
So currently you have:
   import all
You can just add one like this (name the pool and use whatever subnet whatever you like)
ip dhcp pool VLAN20
 network 192.168.20.0 255.255.255.0
 default-router 192.168.20.1
 lease 7 (if you want to put a lease timer on the address)
Do the same for VLAN 99 or any others you like. As long as the port is in the proper VLAN and you have the subinterfaces setup correctly they should pull an IP address without issues.
Please rate my posts if you find them helpful
