Connecting Cable Modem Through 3560 Switch
mirsalaradili
I have a 3560 series switch and two comcast cable modems. I connected the modems to them switch via cross over cables and set an OSPF routing on their subnets. I connected my wireless router to another port of the switch and set its gateway IP on the switch port. I can ping the modem with the switch and I can ping the wireless too. But I cannot access to the Internet via the wireless router.
Can anybody help me? Tell me what is the process to accomplish this task. I need load balancing on two cable modems and get a single network connection via the wireless router.
48 Replies 48
yzeledon
Here is the scenario as I see it:
Modem-------|
                        |-----------Switch------------- Wireless Router
Modem-------|
You can have 2 default routes on the switch pointing to the Cable Modems, no need for OSPF. If you use multiple ip route 0.0.0.0 0.0.0.0 commands, traffic is load-balanced over the multiple routes:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094374.shtml#route0.0
Remember to have the cable modems on different SVI's or issue the "no switport" command on the interfaces attached to the modems.
Configure the Wireless router to send all traffic to the switch.
In order for OSPF or any other routing protocol to work, you'll need the modems to use that same protocol.
Let me know how things work.
Cheers,
Yanil
Thanks, but i have some problems with this switch. Here is the scenario and what i do:
Modem |-------------------------------|
10.10.10.1 255.255.255.0
                                             |-------------Switch-----------|Wireless Router
Modem |-------------------------------|                                    10.0.0.14 255.255.255.0
20.20.20.2 255.255.255.0
Switch(config)#ip routing
Switch(config)#int fast0/2
Switch(config-if)#ip address 20.20.20.1 255.255.255.0
Switch(config-if)#^Z
Switch#config t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)#int fast0/3
Switch(config-if)#ip address 10.0.0.1 255.255.255.0
Switch(config-if)#int fast0/1
Switch(config-if)#no switchport
Switch(config-if)#ip address 10.10.10.2 255.255.255.0
Switch(config-if)#exit
Switch(config)#ip defa
Switch(config)#ip default-network 20.20.20.2
Switch(config)#ip default-network 10.10.10.1
Switch(config)#exit
But my routing table won't change and I get this (plus I cannot access to the Internet through my wireless router):
Switch#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set  <------------------------------------------------------------------- See!
     20.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       20.20.20.0/24 is directly connected, FastEthernet0/2
S       20.0.0.0/8 [1/0] via 20.20.20.2
     10.0.0.0/24 is subnetted, 1 subnets
C       10.0.0.0 is directly connected, FastEthernet0/3
What am i doing wrong?
This is an example of configuring a gateway of last resort using the ip route 0.0.0.0 0.0.0.0 command:
Switch#configure terminal
   Switch(config)#ip route 0.0.0.0 0.0.0.0 10.10.10.1
   Switch(config)#ip route 0.0.0.0 0.0.0.0 20.20.20.2
   Switch(config)#^Z
   Switch#
Let me know how it works.
Remember to enable "ip routing".
Cheers,
Yanil
now I can ping www.google.com from the switch, but my wireless router is not connected to the internet..!! This should not be this hard, it is driving me nuts!!! What do you think is the problem? My wireless router ip address is 10.0.0.14 and the port on the switch which it is connected to is 10.0.0.1. Also i can ping the wireless router from the switch.
Thanks again for your quick replies.
Any other clue???
The configuration on the switch is right, so know, to test it u can attach a computer directly to the switch. Although you may want to check the configuration on the AP, are you using the IP address of the switch as the default gateway for the AP? DG should be 10.0.0.1.
Cheers,
Yanil
The port on the switch which the AP is connected to is on "no switchport" and has this IP: 10.0.0.1 255.255.255.0
So the DG set on the AP is 10.0.0.1 and the AP itself has an IP address in that range.
I can even ping to modem with the wireless router but not the Internet. Do you know why?
Also when I connect my laptop to another port of the switch I have no access to the internet. I have internet access on the switch but when I connect a wireless router to it or my own laptop it drops packets. What should I do?
Are you using the IP address of the switch as your default gateway? Can I see the configuration of the switch?
Cheers,
Yanil
What do you mean by IP address of the switch? Which port's IP address are you referring to?
Here is a full "show run" information:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
boot-start-marker
boot-end-marker
no logging console
enable password admin
no aaa new-model
system mtu routing 1500
ip routing
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
no switchport
interface FastEthernet0/2
no switchport
interface FastEthernet0/3
no switchport
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
no switchport
ip address 30.30.30.1 255.255.255.0
interface FastEthernet0/8
interface GigabitEthernet0/1
interface Vlan1
no ip address
ip classless
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 0 4
login
line vty 5 15
login
end
I connected my laptop to FastEthernet 0/7 and gave the IP address to the port.
Please tell me what am i doing wrong?
Any ideas?
Yes, I do see what we are missing:
1-      We still need one more default static route to the other modem.
2-      We need a NAT configuration.
Here is how you should do it:
no switchport
ip nat outside
no switchport
ip nat outside
no switchport
ip nat inside
access-list 1 permit 10.0.0.0 0.0.0.255
ip nat inside source list 1 FastEthernet0/1 overload
ip nat inside source list 1 FastEthernet0/2 overload
This should solve the problem, sorry for the late response.
Cheers,
Yanil
Well the switch that I am using is a 3560 serie, so I do not think it supports NAT commands. Is there anyway to go around it and maybe use some other configurations? It is odd that the switch itself can ping 4.2.2.2 and my laptop or the wireless router which are connected to it can't! Also another wierd thing is that when I used Fast0/2 as a trunk port, my laptop seemed to be connected (the icon under there said i have access to the internet) but I could not ping 4.2.2.2!!!
So what do you think?
I do see it doesn't support NAT, my bad!
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a008011c629.shtml
Both modems are only going to route for the 10.10.10.0 and 20.20.20.0 address. So maybe we can include the computer or the AP on the same VLAN (creating a VLAN for each modem) with the modems but that is not going to load balance at all.
Let me reproduce this on my LAB and see what woraround I can find.
Cheers,
Yanil
