connecting cisco 2811 to ISP
I have a problem connecting the cisco router to my Xfinity ISP router. I can ping all devices in my network but cannot go outside or ping my default route.
here is my configuration:
hostname R12
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip domain name aalmaweri.net
archive
log config
  hidekeys
interface FastEthernet0/0
ip address dhcp
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.10.10.1 255.255.255.0
ip nat outside
duplex auto
speed auto
ip default-gateway 10.0.0.1
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 10.10.10.0 0.0.0.255
control-plane
line con 0
Password cisco
Login
line aux 0
line vty 0 4
Password cisco
login
Thank you;
your XFinity needs a route back to the 10.10.10.0/24 network. In addition, make sure your configuration looks like below (important parts marked in bold):
hostname R12
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
archive
log config
hidekeys
ip address dhcp
ip nat outside
duplex auto
speed auto
--> ip nat inside
duplex auto
speed auto
--> ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp
control-plane
line con 0
Password cisco
Login
line aux 0
line vty 0 4
Password cisco
login
6 Replies 6
Muhammad Awais Khan
can you check the status of interface fa0/0 by "show ip interface bri" ? See what IP it got. Will it get IP 10.0.0.x ?
You can also change the below static Routes
no ip default-gateway 10.0.0.1
no ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip route 0.0.0.0 0.0.0.0 DHCP
I did everything and still can’t communicate
Martin L
replace current statid/default settings with
hostname R12
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
archive
log config
hidekeys
ip address dhcp
ip nat outside
duplex auto
speed auto
--> ip nat inside
duplex auto
speed auto
control-plane
line con 0
Password cisco
Login
line aux 0
line vty 0 4
Password cisco
login
Georg Peacocks的回答是正确的。
接口的配置解释:
FastEthernet0/0是连接ISP的接口,应该配置成:ip nat outside
FastEthernet0/0接口会通过ISP获取到一个公网IP地址。
FastEthernet0/1是连接内部的网络,应该配置成: ip nat inside
默认路由配置解释:
默认路由的下一跳你应该询问ISP的工程师。假设ISP的工程师告诉你,你的默认路由下一跳地址是:100.100.100.100
那么你应该配置:ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 100.100.100.100
NAT配置解释:
你允许10.10.10.0/24私网地址通过NAT转换成一个公网地址进行上网。
Georg Peacocks' answer is correct.
Interface configuration explanation:
FastEthernet0 / 0 is the interface to the ISP, and should be configured as: ip nat outside
The FastEthernet0 / 0 interface will obtain a public IP address through the ISP.
FastEthernet0 / 1 is connected to the internal network and should be configured as: ip nat inside
Explanation of the default routing configuration:
ip route 0.0.0.0 0.0.0.0 FastEthernet0 / 0 dhcp
You should ask your ISP ’s engineer for the next hop of the default route. Suppose the ISP engineer tells you that your default route next hop address is: 100.100.100.100
Then you should configure: ip route 0.0.0.0 0.0.0.0 FastEthernet0 / 0 100.100.100.100
Explanation of NAT configuration:
ip nat inside source list 1 interface FastEthernet0 / 0 overload
You allow 10.10.10.0/24 private network addresses to be converted to a public network address via NAT for Internet access.
CCIE #62933
Thank you
