Connecting router on a ppp multilink routers
jigsing
Hi everyone,
i'm new to this, i would appreciate any help. thanks
i cannot ping R23 using R22
R21 Config:
R22 Config
:R22 config.PNG
R23 Config:
Topology
2 Accepted Solutions
how is RIPv2 configured on R22 ?
Michael.downing
Hello Jigsing
check your Serial interfaces. Clock rate is only required on one end. Read up on DCE / DTE
On R21 and R23 I can see RIP is configured. On R22 however there is no shown RIP configuration, and it looks like there isnt any. No shown Static Routes either. I suspect that you dont have routing in place for the ping to work. Nor the Correct Serial interface configuration.
Check pings are successful between each device to isolate issue locations.
Best Regards
Michael
Thanks for the help, the problem seems to be that i forgot to create a rip on R22 thanks bro
Michael.downing
Hello Jigsing
Best Regards
Michael
