Can someone help me?
bob_0000
Hello everyone,
I am new to networking using the cisco CLI and I have a question. I am trying to do a basic setup for the Cisco 800 series and I am having trouble using internet on my laptop. I get a ip address 192.168.50.3 and with the right lease time.
Here is my running-config
Building configuration...
Current configuration : 997 bytes
version 12.4
no service pad
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
no ip source-route
ip dhcp pool algemeen
network 192.168.50.0 255.255.255.0
default-router 192.168.50.1
ip cef
ip name-server 8.8.8.8
ip name-server 4.4.4.4
no ipv6 cef
archive
log config
hidekeys
interface FastEthernet0
duplex half
speed 100
interface FastEthernet1
interface FastEthernet2
duplex half
speed 100
interface FastEthernet3
interface FastEthernet4
ip address dhcp
duplex auto
speed auto
interface Vlan1
ip address 192.168.50.1 255.255.255.0
no ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
thanks in advance. What am i doing wrong
5 Replies 5
make the changes/additions marked in bold:
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ip source-route
ip dhcp excluded-address 192.168.50.1
dns-server 8.8.8.8 4.4.4.4
ip cef
no ipv6 cef
archive
log config
hidekeys
duplex half
speed 100
duplex half
speed 100
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
no ip http server
ip nat inside source list 1 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet4 dhcp
access-list 1 permt 192.168.50.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Deepak Kumar
Below are the changes:
ip address dhcp
duplex auto
speed auto
ip nat outside
interface Vlan1
Ip nat inside
access-list 99 permt 192.168.50.0 0.0.0.255
ip nat inside source list 99 interface FastEthernet4 overload
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Just like to add
if this router is internet facing suggest at the very least you apply some iOS security to it like a context based access list or zone based firewall if the iOS supports it
The good thing is Cisco provides very simplistic way to secure your router if you don’t know your way around the cli and is to use the inbuilt security macro which will secure you rtr when attaching directly to an unsecured link such as the internet
type the below and follow the instructions:
auto secure full
Kind Regards
Paul
On a side note, is that feature available on the 800 series ? I thought it required an XE release, not sure about that though...
@Georg Pauwen
FYI-
CCO States
Cisco AutoSecure is available in Cisco IOS Software Major Release 12.3 and subsequent 12.3 T releases for the Cisco 800, 1700, 2600, 3600, 3700, 7200, and 7500 Series routers.
Kind Regards
Paul
