Connecting to server on client network via ADSL
bradlesliect
ADSL Router setup at a client site. Router has following config for client network
interface FastEthernet0
description connected to cleint-inside
interface Vlan1
ip address 172.16.111.254 255.255.252.0
ip nat outside
ip virtual-reassembly
ip tcp adjust-mss 1452
Would I just add in ' ip nat inside source static tcp 172.16.113.2 3389 interface Dialer0 3389' to connect to the server on the client network from outside?
I'm using a 877W ADSL router. What other config extract can I provide to get this working?
I want to do it this way because I cannot get the VPN to our office network working.
Please help.
jheckart
Level 3
Level 3
That should work.
You'll also need 'ip nat inside' on the vlan1 interface, and 'ip nat outside' on the dialer0 interface.
Good Luck.
Would you like to see the entire config for this router?
I am also battling to get the VPN connection up.
Did nat work out for you?
Post your config, and the VPN piece should be simple as well.
