Connecting two Cisco 878 G.SHDSL routers back to back and one of them with home broadband router
Theofilos Gk
Hi! I have o problem with cisco 878. I want to connect them back to back with g.shdsl and one of the with broadband router (no cisco). I have configure both 878 with atm, dialer and tunnel interface. I have also ospf protocol over tunnel. One PC is connected in one router and the other router is connected to the broadband router. The PC's ping passes through g.shdsl successfully and reaches the ip of the tunnel of the other router. But here is the problem. It can't route/switch to the vlan. The vlan and the Tunnel are in the routing table. Moreover broadband's router mac address is on the arp table of the router. What can i do to solve the problem? Thank you!
19 Replies 19
it is unclear what your physical setup looks like. Can you post a schematic drawing including all devices ?
Here is the connections. The broadband router is no Cisco!
thanks for the drawing. Basically you don't need a tunnel. You assign the physical ATM interfaces to a dialer pool, and then put IP addresses on both dialers, such as in the example below. It might help if you post the full configs of both 878 routers, that way it is easier to see what is needed.
878-1
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer0
ip address 1.1.1.1 255.255.255.0
encapsulation ppp
dialer pool 1
dialer-group 1
dialer-list 1 protocol ip permit
878-2
interface ATM0
no ip address
pvc 8/35
interface Dialer0
ip address 1.1.1.2 255.255.255.0
encapsulation ppp
dialer pool 1
dialer-group 1
I have the tunnel interfaces because it was the only way to have the ospf running. They couldn't form an adjacency but with the tunnel the did it. I will post the configurations. That you for your support.
odd. Did you try to configure the adjacent interfaces with 'ip ospf network point-to-multipoint' ?
Either way, looking forward to seeing the configs...
Here is the configuration of the first 878. This one is connected with the broadband router.
version 12.4
no service pad
hostname Tasseas_1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
no ip domain lookup
username Tasseas password 0 cisco
username Tasseas_2 password 0 cisco
archive
log config
hidekeys
controller DSL 0
mode atm
line-term co
line-mode 2-wire line-zero
dsl-mode shdsl symmetric annex A
line-rate auto
bridge irb
interface Tunnel0
ip address 192.168.7.1 255.255.255.0
tunnel source Dialer0
tunnel destination 192.168.6.2
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
ip address 192.168.3.1 255.255.255.0
pvc 8/35
broadcast
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
interface Vlan30
description DEFAULT GATEWAY
ip address 192.168.60.1 255.255.255.0
interface Dialer0
ip address 192.168.6.1 255.255.255.0
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
redistribute static
network 192.168.1.0 0.0.0.255 area 0
network 192.168.7.0 0.0.0.255 area 0
ip default-gateway 192.168.1.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.254
no ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
And here is the second configuration.
version 12.4
no service pad
hostname Tasseas_2
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
username Tasseas_1 password 0 cisco
archive
log config
hidekeys
controller DSL 0
mode atm
bridge irb
interface Tunnel0
ip address 192.168.7.2 255.255.255.0
tunnel destination 192.168.6.1
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
ip address 192.168.3.2 255.255.255.0
pvc 8/35
broadcast
switchport access vlan 2
interface Vlan1
no ip address
interface Vlan2
ip address 192.168.5.2 255.255.255.0
interface Dialer0
ip address 192.168.6.2 255.255.255.0
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
router ospf 1
router-id 2.2.2.2
network 192.168.5.0 0.0.0.255 area 0
ip default-gateway 192.168.6.2
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
what if you disable the tunnels and configure the below (on both routers), do the dialer interfaces form an OSPF adjacency ?
interface Dialer0
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
router ospf 1
router-id 2.2.2.2
network 192.168.6.0 0.0.0.255 area 0
Hi! With your configuration the two 878 made an adjancency without the tunnel interaface but with the dialer. But even with that change the PC cannot ping broadband router . The traceroute from the pc to broadband router stops to the dialer interface(first hop 192.168.5.2, second hop 192.168.6.1) and then request timed out.
I have simplified your configurations, check if you get it to work this way. Important parts are marked in bold.
That said, I assume all your clients need Internet connectivity ? Your broadband router dishes out addresses in the 192.168.1.0/24 range, that is most likely all that is being translated. So you might need double NAT (unless you have added the additional networks to the broadband router). I have added optional lines (bold/italic) which you could add in case your clients don't all have Internet access...
version 12.4
no service pad
hostname Tasseas_1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
no ip domain lookup
archive
log config
hidekeys
controller DSL 0
mode atm
line-term co
line-rate auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
pvc 8/35
broadcast
interface Vlan1
ip nat outside
interface Vlan30
ip nat inside
interface Dialer0
ip nat inside
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
router ospf 1
router-id 1.1.1.1
network 0.0.0.0 255.255.255.255 area 0
ip nat inside source list 1 interface Vlan1 overload
access-list 1 permit 192.168.0.0 0.0.255.255
no ip http server
control-plane
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
login
end
Router 2
version 12.4
no service pad
hostname Tasseas_2
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
archive
log config
hidekeys
controller DSL 0
mode atm
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
pvc 8/35
broadcast
interface Vlan1
no ip address
interface Vlan2
interface Dialer0
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
router ospf 1
router-id 2.2.2.2
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
The new configuration has the same result. The pc can ping the 878 but 878 cant ping pc. I believe that is a switching problem. For example i can ping from pc to the vlan1 (192.168.1.1) of the 878 which is connected to broadband router but i cant ping the default gateway (192.168.1.254).
can you post the output of 'show ip route' for both routers ?
Hi! I will post the  " show ip route" in a few days because i had to leave from my work for a few days. Thank you.
Hi! The things getting better. My pc can ping the default gateway but the Taseas_1 (that is connected to the default gateway) can't ping my pc.
can you post both the configurations you currently have ?
