connection between two vlans on same router
zaprian22
hi,
my problem is this:
we have two 2811 router with configured interfaces:
Router1
interface FastEthernet0/0.380
encapsulation dot1Q 380
ip address 192.168.232.18 255.255.255.248
no snmp trap link-status
crypto map clientmap
interface FastEthernet0/0.382
encapsulation dot1Q 382
ip address 10.132.1.126 255.255.255.252
interface Vlan1
ip address 192.168.5.1 255.255.255.128
ip nat inside
ip virtual-reassembly
ip route 0.0.0.0 0.0.0.0 192.168.232.17
ip route 10.132.254.35 255.255.255.255 10.132.1.125
Router2
interface FastEthernet0/0.197
encapsulation dot1Q 197
ip address 192.168.222.2 255.255.255.248
ip nat inside
no cdp enable
interface Vlan1
ip address 192.168.1.1 255.255.255.128
ip nat inside
ip tcp adjust-mss 1452
so my case is:computer from router1's network can ping 192.168.222.2 (router2 -FastEthernet0/0.197 )
computer from router2 network can ping 192.168.232.18 (router1- FastEthernet0/0.380),but can't ping 10.132.1.126 (router1- FastEthernet0/0.382)
How can i connect vlan 380 and vlan382.I want the three vlan to see each other.Is this happen with IRB or not?
TNX
11 Replies 11
fgasimzade
Level 4
Level 4
Can you please post traceroute result from computer2 to 10.132.1.126
we are missing a diagram with which is connected to which.
Regards.
Alain
before that i'm sorry because i did't post the routes for router2:
ip route 192.168.0.0 255.255.0.0 192.168.222.1
ip route 10.132.1.124 255.255.255.252 192.168.232.18
and the result ot traceroute:
traceroute to 10.132.1.126 (10.132.1.126), 30 hops max, 60 byte packets
1  192.168.1.1 (192.168.1.1)  5.667 ms  6.185 ms  6.570 ms
2  192.168.222.1 (192.168.222.1)  1.020 ms  1.018 ms  1.002 ms
3  192.168.222.2 (192.168.222.2)  6.871 ms  7.953 ms  8.575 ms
4  192.168.222.1 (192.168.222.1)  1.413 ms  1.395 ms  1.372 ms
5  192.168.222.2 (192.168.222.2)  8.877 ms  9.260 ms  9.659 ms
6  192.168.222.1 (192.168.222.1)  1.569 ms  1.496 ms  1.477 ms
7  192.168.222.2 (192.168.222.2)  9.284 ms  9.151 ms  9.551 ms
8  192.168.222.1 (192.168.222.1)  1.408 ms  1.433 ms  1.313 ms
and from computer2 another traceroute:
traceroute to 192.168.232.18 (192.168.232.18), 30 hops max, 60 byte packets
1  192.168.1.1 (192.168.1.1)  1.919 ms  2.259 ms  2.626 ms
2  192.168.222.1 (192.168.222.1)  0.897 ms  0.897 ms  0.871 ms
3  192.168.232.17 (192.168.232.17)  2.878 ms  2.869 ms  2.846 ms
4  192.168.232.18 (192.168.232.18)  3.104 ms * *
What device is 192.168.222.1 ?
192.168.222.1 and 192.168.232.17, 10.132.1.125 -  my ISP switches.They actually don't want to map vlan380 and vlan382,but they've been mapped vlan380 and vlan197
All ports are trunks and vlan 382 is Sip trunk.My PBX is in router2's lan
Ok, as I can see from the traceroute, Router2 doesnt know how to reach 10.132.1.124, thats why it sends packet to 192.168.222.1
It means that this route on Router 2
is not working.
If you issue show ip route static on your Router2 I believe you will not see this route because next-hop (192.168.232.18) is not available
Check routing table on 192.168.222.1 to see if there is a route to 10.132.1.124 255.255.255.252
yes there is route,but look at this:
router1#ping 10.132.1.125
Sending 5, 100-byte ICMP Echos to 10.132.1.125, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/8 ms
router1#ping 10.132.1.125 source fastEthernet 0/0.380
Packet sent with a source address of 192.168.232.18
Success rate is 0 percent (0/5)
router1#ping 192.168.232.17 source fastEthernet 0/0.382
Sending 5, 100-byte ICMP Echos to 192.168.232.17, timeout is 2 seconds:
Packet sent with a source address of 10.132.1.126
so there is no connection between fa0/0.380 and fa0/0.382
that's why i ask is it possible to some kind configure IRB or something.
if i configure nat between fa0/0.380 and fa0/0.382 ping appears between these two subinterfaces but ping from fa0/0.197 to fa0/0.382 still not respond.
I think both fa0/0.380 and fa0/0.382 are not mapped each other on the other side.
oh sorry.i don't see that you mean routing table on 192.168.222.1
actually i don't know.i don't have access.i think there isn't
Well, I have never dealt with IRB, but it is not about vlan mapping, it is about rouiting
This:
Happens because there is no route from 10.132.1.125 to 192.168.232.18, device 10.132.1.125 doesnt know where to send packets destined to 192.168.232.18. If it is a computer, its default gateway should point to router1 FastEthernet0/0.382 interface (10.132.1.126)
The same happens here:
192.168.232.17 doesnt know how to reach 10.132.1.126. Again, if it is a computer, check its default gateway
"oh sorry.i don't see that you mean routing table on 192.168.222.1
actually i don't know.i don't have access.i think there isn't"
Well, I believe this is what causing problems
yes i know it.but i don't know alternative method to bypass this:) any suggestions?
You can ask your ISP to configure addition vlan between two routers, configure point-to-point ip addresses between routers and you will be able to route trafic without ISP
