Connection error
MilezMontego
I would appreciate any help!
I am working on "Getting Started with Cisco Packet Tracer. Deploying devices in the packet Tracer but keeps getting this error message.
Blue_Bird
Hello MilezMontego,
Please go throgh the following video...that provides the steps to fix your issue...
https://www.youtube.com/watch?v=j2UdqVO_Qa8
Best regards
******* If This Helps, Please Rate *****
M02@rt37
Hello @MilezMontego
The issue is when you want to plug your PC to the Home Wireless router ? So, be ure to not use USB port on the PC...
Use the "automatic connextion type" to ensure to use the good cable and the good port.
Best regards
@MilezMontego
 If you hover the cursor over the camera, you probably will see that it supports only wireless and bluetooth. If you check on the device config you might get to the same conclusion.
I believe in the past Cisco had cameras with Ethernet port but it seems it not the case anymore.
