10-10-2024 12:20 AM
Dear Community Members.,
I have a 2901 router that need to push about 500mb Data traffic via Its Gigabits Port.
Do I need a License and how can i get one to be able to achieve this/
10-10-2024 04:12 AM
2901 is end of life. It is not possible to buy licenses.
10-10-2024 08:17 AM
as @Flavio Miranda , you wont be getting any License the product EOL, may be you need uplift product to latest model and buy higher throughput License.
ISR 4K or future is Cisco 8K Model
10-11-2024 05:59 AM
It isn't licensing even if there were a license available. This is particularly true with routers. Just because it has 2 gigabit ports doesn't mean it can push 2 gigabits worth of throughput. I found another thread that indicates the most this user could push through a 2901 was 400Mb. I don't find that surprising at all.
10-11-2024 06:36 AM
I don't recall the 2900 ISR series having performance licenses like the 4000 ISR series except possibly for crypto.
I might have some performance info to attach (later) but I also recall the 2900 ISR serious performance is very, very variable based on the traffic, itself, and the router's configuration.
BTW, @Elliot Dierksen correctly points out a common issue with many ISRs, in that they are often incapable of (sustained) wire-rate for their ports. (NB: often the interface NICs can sustain wire-rate but the ISR's forwarding often cannot.)
10-11-2024 07:51 AM - edited 10-11-2024 03:27 PM
