connection of 880 router and firewall/password
petercinvest
Dear expert, I connect through console, may I know the default user name and password for cisco 880 router console port?
my switch is connected to the checkpoint UTM edge firewall, how the firewall connect to 880 router, through which port of the cisco router?
how my 880 router connect to HP ISP internet router, through which port of the cisco router? thanks
5 Replies 5
User name and password on console can be stored on router database or on a tacacs server.
Line console 0
login local
Username cisco password cisco
If you issue show run command you can see user name and password. If you use
Username cisco secrect cisco, your password will be stored encrypted.
2- You can ping your devices from your router and check the arp table.
Show arp or show arp-table [Check the command with ? mark. it varies on different router]
If you could not find the exact interface, copy the mac-address corresponding to your firewall IP and chack mac-address table to find the exact interface.
Show mac address-table
Hope it helps,
Masoud
No, currently all devices are not connected. I'm asking how to physically connect them, as there are so many ports at back panel for firewall and router. this is the first time setup
not connected how to show arp?
console is password protected, how to show run? I think it is default user name and password, pls advice
You need to connect port 1 to your HP internal router and port 5 to your firewall edge router. I supposed your firewall is connected to the Internet.
You connect to your router by console.
If it asks username and passwork, enter cisco.
Please watch this video which helps you to connect to your router by putty software
https://www.youtube.com/watch?v=yRYF62czX6g
This one for basic configuration
https://www.youtube.com/watch?v=BnaA0_zmpXA
Masoud
No, as in my original thread, HP router is the ISP router, connecting to internet, my 880 is internal router, pls re-advice the physical connection of the ports of different network device: internet router, 880 router and firewall (checkpoint).
Try cisco /cisco as username and password in console.
Have a look on the below link for basic setup cisco 800 series routers.
http://www.cisco.com/c/en/us/td/docs/routers/access/800/837/hardware/quick/guide/qsg/837qsg.html
and if you want to perform password recovery for router then check out the below link.
http://www.cisco.com/c/en/us/support/docs/routers/800-series-routers/12065-pswdrec-827.html
Hope it Helps..
-GI
Rate if it Helpss
