Connection via fibre
Highnet_TSC
I am trying to identify the most basic Cisco router availble which will allow a fibre connection on the WAN port, either directly or via SFP.
Could somebody please advise?
Sandeep Choudhary
Its all depends wt u need from this router.
I am not much familier about router types but still:
U can use cisco 3900 series router:
• The Cisco 3900 Series provides up to four 10/100/1000 Ethernet WAN ports.
•  Two of the 10/100/1000 Ethernet WAN ports on the Cisco 3900 Series can  support Small Form-Factor Pluggable (SFP)-based connectivity in lieu of  RJ-45 ports, enabling fiber connectivity.
or you can check this router- Cisco 892F(just check before buying!)
please rate if it helps.
Sandeep Choudhary
I'd just identified the 892F myself by tackling the question from a different angle (the SFP compatibility matrix), but thanks for the confirmation.
Cheers
