Connectivety Problem after switching router/link
gohengchai
Dear All,
I'm stuck with a problem encountered recently, hope the kind souls here
could give me a clue to the problem.
Currently we have a 64kbps circuit to a remote site and we have plan to
move it to a new circuit (T1) on a new router. I have recently
performed a test on a new circuit (faster) on the new router to the
remote site.
I configured the new router on the T1 having the same internal
interface IP address so that I do not have to change the default
gateway on the clients configured with static addresses. I did the
switch by disconnecting the link on the router connected to the 64kbps.
All went well except only a single host at secured vlan20 and another
host at the remote site have problems connecting to each other.The
affected host on vlan20 has no problems connecting to the other hosts
at the remote site.
The connectivety between the other secured vlans to the hosts at the
remote site is fine.
host on vlan20--FWSM--6509--Checkpoint--1721--{IPVPN}--1721--Remote
Site
I have cleared the arp-cache on the connected routers/switches/hosts
and even reloaded the devices but it didnt help. traceroute from the
remote site stops at the 6509 core switch and I dont see anything
hitting vlan20 from the FWSM logs. I do see outgoing traffic from the
host on vlan20 hitting the access-list created on the FWSM but it didnt
even hit the checkpoint firewall. It looks likes the traffic stops at
the 6509 but there are no access list applied. ARP Proxy is enabled on the FWSM. Once I switched back to the 65kbps circuit, everything was back to normal.
I'm missing out on something after the change. Strange that it only
happens on this particular host. Hope you guys could advise me.
ecgoh
globalnettech
Level 5
Level 5
when you say 'secured VLAN', what are you referring to, configuration-wise ? Can you post the configurations of all devices involved, and indicate which IP addresses are not able to connect to each other ?
GNT
jackyoung
Level 6
Level 6
Do you mean only occured at two hosts, one at VLAN 20 and one at remote site ? If it is only changed the from 64k to T1, it shouldn't be any L3 problem.
How about if the host at remote try to connect to that host at VLAN 20 ? Where is the packet stop ?
Did you checked w/ the IPVPN provider ?
I suggest to clear the cache of 6509 and firewall as well if possible.
Configuration files are required for detail investigation.
Hope this helps.
