Traffic shaping
alexhang
hi all
under my interface f0/0 i found that there is a traffic shape syntax
traffic-shape rate 10000000 450000 220000 1000
can anyone tell me what does the last 3 figures mean, and also how its it generated?
leonvd79
Level 4
Level 4
Hello Alex,
Traffic shaping uses a mean rate, in your case 10,000,000 bits per second a normal burst of 450,000 bits (per interval) an extended burst of 220,000 (per interval) and a buffer-limit of 1,000 bits (per second).
When you only specify the mean rate, the other values are automatically calculated ( the formula is not disclosed by Cisco ).
If you'd like to tweak the settings you can use this formula as a reference
mean rate = burst size / time interval
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hqos_c/part20/ch10/qsbtsovw.htm
HTH,
--Leon
* Please rate posts.
Hi Leon
Thank you for the info, i have got another question
what does the "show traffic-shape" tells you?
and the figures display, what does these figure tells?
Many thkz
a.hajhamad
Level 4
Level 4
I think the following document will help you.
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1831/products_command_reference_chapter09186a00800807a4.html#1020005
Please rate if it does!
Abd Alqader
