Consequence of changing EIGRP router-ID?
MicJameson1
Hello.
On a production routing device, if change the EIGRP router-ID, what will be the consequences?
My specific admin issue-- When i use command
sh ip eigrp topology A.B.C.D /24
to see the originating router, I often an given an IP that I don't recognize; thus, I'd like to solve this by changing/creating human-logical recognizable router-id's on each device.
But, I worry that if I do this I will crash the network, because maybe the EIGRP neighbor association will break, or at least churn the network.
Please advise on best solution?
Thank you.
I make lab and test,
your you use router-id the EIGRP immediately take effect NOT until you do
clear ip eigrp
process.
see the neighbour is Down/Up
just want to clear this point
thanks
MHM
7 Replies 7
no only sure that you dont use router-id conflict with other router.
note:- may be you need
clear eigrp
process to make new router-id take effect
But, I worry that if I do this i will crash the network, because maybe the EIGRP neighbor association will break, or at least churn the network.
Thank you.
Hello!
You can change the router-ID (the EIGRP router ID is chosen as the highest IP address on an active interface on the router, unless loopback interfaces are configured).
If you change it the router-id the neighbors will form back on the new router-id's (you might want to do a
clear ip eigrp
neighbors) but there won't be any issue because the in connecting interfaces will remain the same...
Just make sure you don't duplicate router-id's!
****Kindly rate all useful posts*****
clear ip eigrp
process.
thanks
MHM
Thank you for your inspired effort MHM!
QUESTION: How much time elapses before an EIGRP neighbor reports to its upstream neighbors that a downstream neighbor is offline? (In the above picture, the adjacency restores in less than a second. Did the next hop upstream router send information throughout the network that the downstream router was offline?)
Thank you.
I will share debug of EIGRP notify in all router, it will give clear view of EIGRP behave when router-id change
