Consider one router having ospf neighborship with mutilple routers on its subinterfaces;However we came to know, Due to some MT
TM-Pravin
Consider one router having ospf neighborship with mutilple routers on its subinterfaces;However we came to know, Due to some MTU mismatch issue it get stuck in exstart and excahge state.Ho we gonna fix the issue without  changing the mtu on subinterfaces?
on the interfaces, use below command:
(conf-if)# ip ospf mtu-ignore
rosaho
Level 3
Level 3
Posts in this discussion have been modified due to possible misconduct. Please refer to the CSC terms of use for more details.
