Content Switch (11500) configuration help
hlavender
Hi.
I have an application which makes an IP Socket connection between Point A and Point B. What I want to do is put the 11500 between these two points and configure it as follows: If the port is available, route using a persistent connection to Point B. However, if the persistent connection fails, try to reestablish it otherwise move the connection to Point C. I have 800 of these connections which I want to implement.
Can you give me an example of how I can do this?
Point A is 10.10.10.1
Point B is 10.100.1.100 port 51
Point C is 10.200.5.100 port 51
dsweeny
Level 3
Level 3
Secure Sockets Layer (SSL) is an application-level protocol that provides encryption technology for the Internet, ensuring secure transactions such as the transmission of credit card numbers for e-commerce Web sites. SSL provides the secure transaction of data between a client and a server through a combination of privacy, authentication, and data integrity. SSL relies upon certificates, private-public key exchange pairs, and Diffie-Hellman key agreement parameters for this level of security.
This URL should help you:
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_guide_chapter09186a0080292a31.html
