control virus in routers using acl
kp_prasanna
how to block the worm &virus using ACL IN CISCO ROUTERS.
guruprasadr
Level 7
Level 7
HI Prasanna,
Below link will help you a lot:
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00800fc176.shtml#methoda
This will Help you to Understand in 3 Methods:
1.Using ACLs
2.Using PBR
3.Using Class Based Policing
Pls RATE if Helps
Best Regards,
Guru Prasad R
