Controller Card changing
Shibu1978
Dear All,
We have the attached configuration in our cisco 7206 router to facilitate voice calls. VXC-2TE1+ port has been inserted in Slot 1.
Now from one port s1/0 the outgoing calls are not going out but incoming calls are coming through with out any issue. As per the telecom technicians advice we need to change the card in slot 1. we are already procured a temp card for testing.
Now can i just insert the same card just like that ? after insertion do i need to configure everything which was there with the old card or it will be taken from the old card?
Once the testing is over i need to revert back the old card.kindly guide me to test the new card and revert back the old card after testing .
What are the neccessary steps i should follow to carry out the task.
Any response will be highly appreciated.
Shibu
16 Replies 16
As mentioned above, provide a trace for outgoing call failing.
Dear,
I am getting the same message which i have sent you before when doing debug isdn q931.
Now i am in the state of listening to the Telecom technician as i dont much knowledge on this VOIP setup. we plan to change the card to check further.
There are live calls running between offices through this router. while changing the card do i need to configure evrything like DSP,dsp farm,voice ports(attached the current voice related configs in my first post) etc.
Shibu
