convergence between operators
Fernando Galvao
Today my main router is an ASR9001 with 4 ports of 10Gbps being LACP 20Gbps for Wan and LACP 20Gbps for Lan (clients of my internet provider).
This router has a hub switch nexus 3064pa in L2 to expand the ports and is where the operators enter that provides us internet of the following form:
Obrador 1:
PTT IX Brazil 10Gbps (transport to PTT Equinix Sp2 São Paulo Brazil)
Operator 2:
 4Gbps internexa coming from Equinix transport
Operator 3:
6Gbps that I get in my city.
Problem:
Today the consumption is in 3Gbps of the PTT, 2.5Gbps of the internexa and 2.7Gbps of the local operator. When the PTT stops working for a fiber breakdown for example, I have enough bandwidth in the local provider and instead of converging and from 2.7Ghz it rises to 6Gbps, it also drops the traffic for example to 800mbps and even inside the provider itself we stay without internet for a 20min and soon after that it starts to raise the traffic of return until arriving at 6Gbps.
How do I avoid this slow convergence of routes because I just believe that's the problem.
All blocks are announced at the local carrier but not resolved.
Follow the settings for each carrier:
show route IP OPERATOR LINK 6GBPS
Routing entry for IP/32
Known via "static", distance 1, metric 0
Installed Oct 12 14:53:03.146 for 2w4d
Routing Descriptor Blocks
IP
Route metric is 0, Wt is 1
No advertising protos.
show cef  IP OPERATOR 6GBPS/32
IP/32, version 91, internal 0x1000001 0x0 (ptr 0x9dd835ec) [3], 0x0 (0x0), 0x0 (0x0)
Updated Oct 12 14:53:03.153
Prefix Len 32, traffic index 0, precedence n/a, priority 3
via IP /32, 5 dependencies, recursive [flags 0x0]
path-idx 0 NHID 0x0 [0x9dd83580 0x0]
next hop IP/32 via IP/32
show run int bundle-ether 1.22
Tue Oct 31 11:38:03.256 EST
interface Bundle-Ether1.22
description vlan-OPERATOR LINK 6GBPS
ipv4 address IP 255.255.255.252
ipv6 address IPV6/127
flow ipv4 monitor IPV4-FMM sampler 300 ingress
flow ipv4 monitor IPV4-FMM sampler 300 egress
flow ipv6 monitor IPV6-FMM sampler 300 ingress
flow ipv6 monitor IPV6-FMM sampler 300 egress
encapsulation dot1q 22
 neighbor IP OPERATOR LINK 6GBPS
remote-as XXXXXX
ebgp-multihop 10
description OPERATOR LINK 6GBPS-V4
update-source Bundle-Ether1.22
address-family ipv4 unicast
route-policy XXX-V4-IN in
route-policy XXX-V4-OUT out
remove-private-AS
soft-reconfiguration inbound always
Georg Pauwen
post the full configuration of your ASR.
!! IOS XR Configuration 6.1.4
!! Last configuration change at Thu Nov 2 12:14:17 2017 by admin
service unsupported-transceiver
hostname GW-PE-CISCO
clock timezone EST -3
logging 10.99.90.22 vrf default port default
logging xxx.xxx.68.6 vrf default port default
telnet vrf default ipv4 server max-servers 5
cdp
http client source-interface ipv4 MgmtEth0/RSP0/CPU0/0
snmp-server ifindex persist
snmp-server ifmib stats cache
snmp-server host 10.10.10.4 traps version 2c public
snmp-server community public RO IPv4 GERENCIA
snmp-server traps rf
snmp-server traps bfd
snmp-server traps copy-complete
snmp-server traps snmp
snmp-server traps flash removal
snmp-server traps flash insertion
snmp-server traps config
snmp-server traps entity
snmp-server traps selective-vrf-download role-change
snmp-server traps syslog
snmp-server traps system
snmp-server traps frequency synchronization
snmp-server traps addrpool low
snmp-server traps addrpool high
snmp-server traps entity-state operstatus
snmp-server traps entity-state switchover
snmp-server traps entity-redundancy all
snmp-server traps entity-redundancy status
snmp-server traps entity-redundancy switchover
ntp
server 200.160.0.8
server 200.189.40.8
control-plane
management-plane
inband
interface all
allow all peer
address ipv4 10.10.9.0/24
address ipv4 10.10.10.0/24
address ipv4 xxx.xxx.68.0/24
address ipv4 xxx.xxx.119.0/24
ipv4 access-list GERENCIA
10 permit ipv4 10.10.10.0 0.0.0.255 any
20 permit ipv4 xxx.xxx.119.0/24 any
30 permit ipv4 10.10.9.0 0.0.0.255 any
40 permit ipv4 xxx.xxx.68.0/24 any
flow exporter-map NETFLOW_v4
version v9
options interface-table timeout 60
options sampler-table
template data timeout 60
dscp 18
transport udp 2055
source Bundle-Ether2.1100
destination xxx.xxx.68.13
flow exporter-map NETFLOW_v6
version v9
dscp 18
transport udp 2056
source Loopback0
flow monitor-map IPV4-FMM
record ipv4
exporter NETFLOW_v4
cache entries 131070
cache timeout active 60
cache timeout inactive 30
flow monitor-map IPV6-FMM
record ipv6
exporter NETFLOW_v6
sampler-map 300
random 1 out-of 300
description WAN-LACP
mac-address 4c5e.c6a.1801
bundle minimum-active bandwidth 1
interface Bundle-Ether1.21
description vlan-VIVO
ipv4 address xxx.xxx.201.238 255.255.255.252
encapsulation dot1q 21
description vlan-OPERATOR LOCAL 5GBPS
ipv4 address xxx.196.52.38 255.255.255.252
ipv6 address IP/127
interface Bundle-Ether1.902
description PTT-SP-EQUINIX-SP2-IPv4
ipv4 address 187.16.222.130 255.255.248.0
encapsulation dot1q 902
interface Bundle-Ether1.903
description PTT-SP-EQUINIX-SP2-IPv6
ipv6 address 2001:12f8::222:130/64
encapsulation dot1q 903
interface Bundle-Ether1.2425
description INTERNEXA
ipv4 address 177.84.162.14 255.255.255.252
ipv6 address XXX:XXX:680:14:a::b2/126
encapsulation dot1q 2425
interface Bundle-Ether2
description LAN-LACP
interface Bundle-Ether2.10
description NETFLIX
ipv4 address xxxxxx.36.5 255.255.255.252
ipv6 address XXXXXXXXXXXXXX::2/126
encapsulation dot1q 10
interface Bundle-Ether2.11
description GOOGLE
ipv4 address XXX.XXX.33.1 255.255.255.224
ipv6 address XXXXXXXXXXX1000:3::1/64
encapsulation dot1q 11
interface Bundle-Ether2.12
description FACEBOOK
ipv4 address XXXX.XX.34.93 255.255.255.252
ipv6 address XXXXXXXXXXX:face::/127
encapsulation dot1q 12
interface Bundle-Ether2.1100
description VLAN-PE0-CISCO
ipv4 address xxxxxx.37.13 255.255.255.252
ipv6 address XXXXXXXXXXXX:0:1::1/64
encapsulation dot1q 1100
interface Loopback0
ipv4 address xxxxxx.36.1 255.255.255.255
interface MgmtEth0/RSP0/CPU0/0
ipv4 address 10.10.9.11 255.255.255.0
interface MgmtEth0/RSP0/CPU0/1
shutdown
interface TenGigE0/0/2/0
description LACP1-LAN-GW
bundle id 1 mode active
lacp period short
transceiver permit pid all
interface TenGigE0/0/2/1
description LACP2-LAN-GW
lacp period short
interface TenGigE0/0/2/2
bundle id 2 mode active
lacp period short
interface TenGigE0/0/2/3
extcommunity-set rt CIDR_MY-ISP
XXX:XXX:5000
end-set
extcommunity-set rt PEERING_ALL
XXX:XXX:14000
end-set
extcommunity-set rt PEERING_GGC
XXX:XXX:2005
end-set
extcommunity-set rt TRANSIT_ALL
XXX:XXX:12000
end-set
extcommunity-set rt LP-10150-COMM
XXX:XXX:10150
end-set
extcommunity-set rt LP-10190-COMM
XXX:XXX:10190
end-set
extcommunity-set rt CIDR_MY-ISP_v6
XXX:XXX:5001
end-set
extcommunity-set rt DDOS_BGPQRATOR
XXX:XXX:3001
end-set
extcommunity-set rt DOS_CLOUDFLARE
XXX:XXX:3003
end-set
extcommunity-set rt NO-EXPORT-COMM
XXX:XXX:500
end-set
extcommunity-set rt PEERING_AKAMAI
XXX:XXX:2003
end-set
extcommunity-set rt PEERING_ALL_v6
XXX:XXX:15000
end-set
extcommunity-set rt PEERING_GGC_v6
XXX:XXX:2006
end-set
extcommunity-set rt PEERING_TWITCH
XXX:XXX:2018
end-set
extcommunity-set rt TRANSIT_ALL_v6
XXX:XXX:13000
end-set
extcommunity-set rt BLACKHOLE_COMMS
23106:5108
end-set
extcommunity-set rt PEERING_NETFLIX
XXX:XXX:2013
end-set
extcommunity-set rt PEERING_PTT.SPO
XXX:XXX:2001
end-set
extcommunity-set rt CUSTOMER_BGP_ALL
XXX:XXX:10000
end-set
extcommunity-set rt CUSTOMER_BGP_JUA
XXX:XXX:5004
end-set
extcommunity-set rt CUSTOMER_BGP_PNZ
XXX:XXX:5002
end-set
extcommunity-set rt FACEBOOK-COMM-V4
XXX:XXX:2007
end-set
extcommunity-set rt PEERING_FACEBOOK
XXX:XXX:2007
end-set
extcommunity-set rt PEERING_LINKEDIN
XXX:XXX:2009
end-set
extcommunity-set rt PEERING_RIOGAMES
XXX:XXX:2016
end-set
extcommunity-set rt DDOS_BGPQRATOR_v6
XXX:XXX:3002
end-set
extcommunity-set rt PEERING_AKAMAI_v6
XXX:XXX:2004
end-set
extcommunity-set rt PEERING_MICROSOFT
XXX:XXX:2011
end-set
extcommunity-set rt PEERING_TWITCH_v6
XXX:XXX:2019
end-set
extcommunity-set rt TRANSIT_INTERNEXA
XXX:XXX:1001
end-set
extcommunity-set rt DDOS_CLOUDFLARE_v6
XXX:XXX:3004
end-set
extcommunity-set rt PEERING_NETFLIX_v6
XXX:XXX:2014
end-set
extcommunity-set rt PEERING_PTT.SPO_v6
XXX:XXX:2002
end-set
extcommunity-set rt CUSTOMER_BGP_ALL_v6
XXX:XXX:11000
end-set
extcommunity-set rt CUSTOMER_BGP_JUA_v6
XXX:XXX:5005
end-set
extcommunity-set rt CUSTOMER_BGP_PNZ_v6
XXX:XXX:5003
end-set
extcommunity-set rt PEERING_FACEBOOK_v6
XXX:XXX:2008
end-set
extcommunity-set rt PEERING_LINKEDIN_v6
XXX:XXX:2010
end-set
extcommunity-set rt PEERING_RIOGAMES_v6
XXX:XXX:2017
end-set
extcommunity-set rt PEERING_MICROSOFT_v6
XXX:XXX:2012
end-set
extcommunity-set rt TRANSIT_INTERNEXA_v6
XXX:XXX:1002
end-set
prefix-set GA-V4-IN
XXX.XXX.83.196.0/22 ge 22 le 24
end-set
prefix-set GGC_v4_IN
# Listar os prefixos a serem recebidos do GGC
0.0.0.0/0 le 32
end-set
prefix-set PTT-V6-IN
2000::/3 ge 3 le 48
end-set
prefix-set OPERATOR LOCAL 6GBPS-V6-IN
2000::/3 ge 3 le 48
end-set
prefix-set GGC-V4-out
XXX.XXX.68.0/22 ge 24 le 24,
xxxxxx.36.0/22 ge 24 le 24,
XXX.XXX.XXX.32.0/22 ge 24 le 24,
XXX.XXX.XXX.196.0/22 ge 22 le 24
end-set
prefix-set GGC_v4_OUT
# Listar os prefixos a serem anunciados para o GGC
XXX.XXX.79.32.0/22 ge 24 le 24,
end-set
prefix-set PTT-V4-out
end-set
prefix-set PTT-V6-OUT
XXX:XXX:2728::/32 ge 32 le 48,
XXX:XXX:386c::/32 ge 32 le 48
end-set
prefix-set PTT_v4_OUT
end-set
prefix-set OPERATOR LOCAL 6GBPS-V4-OUT
end-set
prefix-set OPERATOR LOCAL 6GBPS-V6-OUT
XXX:XXX:2728::/32 ge 32 le 32
end-set
prefix-set DISCARD_ALL
end-set
prefix-set GA-V4-1-OUT
XXX.XXX.83.196.0/24 ge 24 le 24
end-set
prefix-set GA-V4-2-OUT
XXX.XXX.83.197.0/24 ge 24 le 24
end-set
prefix-set GA-V4-3-OUT
XXX.XXX.83.198.0/24 ge 24 le 24
end-set
prefix-set GA-V4-4-OUT
XXX.XXX.83.199.0/24 ge 24 le 24
end-set
prefix-set AKAMAI_v4_IN
# Listar os prefixos a serem recebidos da Akamai
0.0.0.0/0 le 32
end-set
prefix-set AKAMAI_v4_OUT
# Listar os prefixos a serem anunciados para a Akamai
end-set
prefix-set NETFLIX-V4-out
XXX.XXX.68.0/22 ge 25 le 25,
xxxxxx.38.0/22 ge 25 le 25,
XXX.XXX.79.32.0/22 ge 25 le 25,
XXX.XXX.83.196.0/22 ge 22 le 25
end-set
prefix-set INTERNEXA-V6-IN
2000::/3 ge 3 le 48
end-set
prefix-set INTERNEXA_v4_IN
0.0.0.0/0 le 32
end-set
prefix-set INTERNEXA-V6-OUT
XXX:XXX:2728::/32 ge 32 le 33,
XXX:XXX:386c::/32 ge 32 le 33
end-set
prefix-set Anuncio_GA-V4-OUT
XXX.XXX.79.32.0/22 ge 22 le 24
end-set
prefix-set FULL-ROUTE-V4-OUT
0.0.0.0/0 le 24
end-set
prefix-set recebe_full_route
0.0.0.0/0 le 32
end-set
prefix-set CDN-FACEBOOK-V4-IN
0.0.0.0/0 le 32
end-set
prefix-set CDN-FACEBOOK-V6-IN
2000::/3 ge 3 le 48
end-set
prefix-set CDN-FACEBOOK-V4-OUT
xxxxxx.38.0/22 ge 24 le 24,
XXX.XXX.83.196.0/22 ge 24 le 24
end-set
prefix-set CDN-FACEBOOK-V6-OUT
end-set
prefix-set OPERATOR LOCAL 6GBPS-XXX.XXX.79.32.0-OUT
XXX.XXX.79.32.0/24 ge 24 le 24
end-set
prefix-set OPERATOR LOCAL 6GBPS-XXX.XXX.79.33.0-OUT
XXX.XXX.79.33.0/24 ge 24 le 24
end-set
prefix-set OPERATOR LOCAL 6GBPS-XXX.XXX.79.34.0-OUT
XXX.XXX.79.34.0/24 ge 24 le 24
end-set
prefix-set OPERATOR LOCAL 6GBPS-XXX.XXX.79.35.0-OUT
XXX.XXX.79.35.0/24 ge 24 le 24
end-set
prefix-set OPERATOR LOCAL 6GBPS-XXX.XXX.68.0-OUT
XXX.XXX.68.0/24 ge 24 le 24
end-set
prefix-set OPERATOR LOCAL 6GBPS-XXX.XXX.69.0-OUT
XXX.XXX.69.0/24 ge 24 le 24
end-set
prefix-set OPERATOR LOCAL 6GBPS-XXX.XXX.70.0-OUT
XXX.XXX.70.0/24 ge 24 le 24
end-set
prefix-set OPERATOR LOCAL 6GBPS-XXX.XXX.71.0-OUT
XXX.XXX.71.0/24 ge 24 le 24
end-set
prefix-set OPERATOR LOCAL 6GBPS-xxxxxx.36.0-OUT
xxxxxx.36.0/24 ge 24 le 24
end-set
prefix-set OPERATOR LOCAL 6GBPS-xxxxxx.37.0-OUT
xxxxxx.37.0/24 ge 24 le 24
end-set
prefix-set OPERATOR LOCAL 6GBPS-xxxxxx.38.0-OUT
xxxxxx.38.0/24 ge 24 le 24
end-set
prefix-set OPERATOR LOCAL 6GBPS-xxxxxx.39.0-OUT
xxxxxx.39.0/24 ge 24 le 24
end-set
prefix-set OPERATOR LOCAL 6GBPS-XXX.XXX.79.32-22-OUT
XXX.XXX.79.32.0/22 ge 22 le 22
end-set
prefix-set OPERATOR LOCAL 6GBPS-XXX.XXX.79.32-23-OUT
XXX.XXX.79.32.0/23 ge 23 le 23
end-set
prefix-set OPERATOR LOCAL 6GBPS-XXX.XXX.79.34-23-OUT
XXX.XXX.79.34.0/23 ge 23 le 23
end-set
prefix-set BLACKHOLE_HOST_ROUTES
0.0.0.0/0 ge 32
end-set
prefix-set OPERATOR LOCAL 6GBPS-XXX.XXX.68-22-OUT
XXX.XXX.68.0/22 ge 22 le 22
end-set
prefix-set OPERATOR LOCAL 6GBPS-XXX.XXX.68-23-OUT
XXX.XXX.68.0/23 ge 23 le 23
end-set
prefix-set OPERATOR LOCAL 6GBPS-XXX.XXX.70-23-OUT
XXX.XXX.70.0/23 ge 23 le 23
end-set
prefix-set OPERATOR LOCAL 6GBPS-xxxxxx.36-22-OUT
xxxxxx.36.0/22 ge 22 le 22
end-set
prefix-set OPERATOR LOCAL 6GBPS-xxxxxx.36-23-OUT
xxxxxx.36.0/23 ge 23 le 23
end-set
prefix-set OPERATOR LOCAL 6GBPS-xxxxxx.38-23-OUT
xxxxxx.38.0/23 ge 23 le 23
end-set
prefix-set NETFLIX_v4_PREFIXOS_IN
# Listar aqui os prefixos a serem recebidos do Netflix
0.0.0.0/0 le 32
end-set
prefix-set ANUNCIO-XXX.XXX.79.32.0-out
end-set
prefix-set ANUNCIO-XXX.XXX.79.33.0-out
end-set
prefix-set ANUNCIO-XXX.XXX.79.34.0-out
end-set
prefix-set ANUNCIO-XXX.XXX.79.35.0-out
end-set
prefix-set NETFLIX_v4_PREFIXOS_OUT
# Listar aqui os prefixos a serem anunciados para o Netflix
end-set
prefix-set ANUNCIO-XXX.XXX.68.0-out
end-set
prefix-set ANUNCIO-XXX.XXX.69.0-out
end-set
prefix-set ANUNCIO-XXX.XXX.70.0-out
end-set
prefix-set ANUNCIO-XXX.XXX.71.0-out
end-set
prefix-set ANUNCIO-xxxxxx.36.0-out
end-set
prefix-set ANUNCIO-xxxxxx.37.0-out
end-set
prefix-set ANUNCIO-xxxxxx.38.0-out
end-set
prefix-set ANUNCIO-xxxxxx.39.0-out
end-set
prefix-set ANUNCIO-XXX.XXX.79.32-22-OUT
end-set
prefix-set ANUNCIO-XXX.XXX.79.32-23-OUT
end-set
prefix-set ANUNCIO-XXX.XXX.79.34-23-OUT
end-set
prefix-set ANUNCIO-XXX.XXX.68-22-OUT
end-set
prefix-set ANUNCIO-XXX.XXX.68-23-OUT
end-set
prefix-set ANUNCIO-XXX.XXX.70-23-OUT
end-set
prefix-set ANUNCIO-xxxxxx.36-22-OUT
end-set
prefix-set ANUNCIO-xxxxxx.36-23-OUT
end-set
prefix-set ANUNCIO-xxxxxx.38-23-OUT
end-set
prefix-set internexa-XXX.XXX.79.32.0-out
end-set
prefix-set internexa-XXX.XXX.79.33.0-out
end-set
prefix-set internexa-XXX.XXX.79.34.0-out
end-set
prefix-set internexa-XXX.XXX.79.35.0-out
end-set
prefix-set CLIENTES_BGP_FULL_PREFIXOS
# Listar aqui os prefixos de clientes BGP Full de policy comum
end-set
prefix-set INTERNEXA-XXX.XXX.79.32-22-OUT
end-set
prefix-set internexa-XXX.XXX.68.0-out
end-set
prefix-set internexa-XXX.XXX.69.0-out
end-set
prefix-set internexa-XXX.XXX.70.0-out
end-set
prefix-set internexa-XXX.XXX.71.0-out
end-set
prefix-set internexa-xxxxxx.36.0-out
end-set
prefix-set internexa-xxxxxx.37.0-out
end-set
prefix-set internexa-xxxxxx.38.0-out
end-set
prefix-set internexa-xxxxxx.39.0-out
end-set
prefix-set INTERNEXA-XXX.XXX.68-22-OUT
end-set
prefix-set INTERNEXA-xxxxxx.36-22-OUT
end-set
as-path-set FACEBOOK-V4-IN
originates-from '32934',
originates-from '34825',
originates-from '54115'
end-set
route-policy LEO
end-policy
route-policy TESTE
apply FACEBOOK-V4-IN
if destination in recebe_full_route then
pass
endif
end-policy
route-policy GA-V4-IN
if destination in GA-V4-IN then
pass
endif
end-policy
route-policy GA-V4-OUT
if destination in FULL-ROUTE-V4-OUT then
pass
endif
end-policy
route-policy GGC-V4-IN
pass
set local-preference 400
endif
end-policy
route-policy GGC-v4-IN
if destination in GGC_v4_IN then
set local-preference 900
set extcommunity rt PEERING_GGC
endif
end-policy
route-policy PTT-V6-IN
if destination in PTT-V6-IN then
pass
set local-preference 600
endif
end-policy
route-policy OPERATOR LOCAL 6GBPS-V4-IN
pass
endif
end-policy
route-policy OPERATOR LOCAL 6GBPS-V6-IN
if destination in OPERATOR LOCAL 6GBPS-V6-IN then
pass
endif
end-policy
route-policy GGC-V4-OUT
if destination in GGC-V4-out then
pass
endif
end-policy
route-policy GGC-v4-OUT
if destination in GGC_v4_OUT then
pass
endif
end-policy
route-policy PTT-V6-OUT
if destination in PTT-V6-OUT then
pass
else
drop
endif
end-policy
route-policy OPERATOR LOCAL 6GBPS-V4-OUT
if destination in ANUNCIO-XXX.XXX.68-22-OUT then
pass
endif
if destination in ANUNCIO-xxxxxx.36-22-OUT then
pass
endif
if destination in ANUNCIO-XXX.XXX.79.32-22-OUT then
pass
endif
if destination in ANUNCIO-XXX.XXX.79.32.0-out then
pass
endif
if destination in ANUNCIO-XXX.XXX.79.33.0-out then
pass
endif
if destination in ANUNCIO-XXX.XXX.79.34.0-out then
pass
endif
if destination in ANUNCIO-XXX.XXX.79.35.0-out then
pass
endif
if destination in ANUNCIO-xxxxxx.36.0-out then
pass
endif
if destination in ANUNCIO-xxxxxx.37.0-out then
pass
endif
if destination in ANUNCIO-xxxxxx.39.0-out then
pass
endif
if destination in ANUNCIO-xxxxxx.38.0-out then
pass
endif
if destination in ANUNCIO-XXX.XXX.68.0-out then
pass
endif
if destination in ANUNCIO-XXX.XXX.69.0-out then
pass
endif
if destination in ANUNCIO-XXX.XXX.70.0-out then
pass
endif
if destination in ANUNCIO-XXX.XXX.71.0-out then
pass
endif
if destination in GA-V4-1-OUT then
pass
endif
if destination in GA-V4-2-OUT then
pass
endif
if destination in GA-V4-3-OUT then
pass
endif
if destination in GA-V4-4-OUT then
pass
endif
end-policy
route-policy OPERATOR LOCAL 6GBPS-V6-OUT
if destination in OPERATOR LOCAL 6GBPS-V6-OUT then
pass
endif
end-policy
route-policy DISCARD_ALL
if destination in DISCARD_ALL then
drop
endif
end-policy
route-policy AKAMAI-v4-IN
if destination in AKAMAI_v4_IN then
set extcommunity rt PEERING_AKAMAI
endif
end-policy
route-policy PTT-SP-V4-IN
pass
endif
end-policy
route-policy AKAMAI-v4-OUT
if destination in AKAMAI_v4_OUT then
pass
endif
end-policy
route-policy NETFLIX-V4-IN
pass
set local-preference 500
endif
end-policy
route-policy NETFLIX-v4-IN
if destination in NETFLIX_v4_PREFIXOS_IN then
set extcommunity rt PEERING_NETFLIX
endif
end-policy
route-policy PTT-SP-V4-OUT
if destination in PTT-V4-out then
pass
endif
end-policy
route-policy FACEBOOK-V4-IN
if as-path originates-from '32934' or as-path originates-from '34825' and as-path passes-through '32934' or as-path originates-from '54115' and as-path passes-through '32934' then
set extcommunity rt FACEBOOK-COMM-V4
endif
end-policy
route-policy NETFLIX-V4-OUT
if destination in NETFLIX-V4-out then
pass
endif
end-policy
route-policy NETFLIX-v4-OUT
pass
endif
end-policy
route-policy INTERNEXA-V4-IN
pass
endif
end-policy
route-policy INTERNEXA-V6-IN
if destination in INTERNEXA-V6-IN then
pass
endif
end-policy
route-policy INTERNEXA-v4-IN
if destination in INTERNEXA_v4_IN then
set local-preference 700
set extcommunity rt (XXX:XXX:1001, XXX:XXX:12000) additive
endif
end-policy
route-policy INTERNEXA-V4-OUT
end-policy
route-policy INTERNEXA-V6-OUT
if destination in INTERNEXA-V6-OUT then
pass
endif
end-policy
route-policy INTERNEXA_v4_OUT
if destination in internexa-XXX.XXX.79.32.0-out then
pass
endif
if destination in internexa-XXX.XXX.79.33.0-out then
pass
endif
if destination in internexa-XXX.XXX.79.34.0-out then
pass
endif
if destination in internexa-XXX.XXX.79.35.0-out then
pass
endif
if destination in internexa-XXX.XXX.68.0-out then
pass
endif
if destination in internexa-XXX.XXX.69.0-out then
pass
endif
if destination in internexa-XXX.XXX.70.0-out then
pass
endif
if destination in internexa-XXX.XXX.71.0-out then
pass
endif
if destination in internexa-xxxxxx.36.0-out then
pass
endif
if destination in internexa-xxxxxx.37.0-out then
pass
endif
if destination in internexa-xxxxxx.38.0-out then
pass
endif
if destination in internexa-xxxxxx.39.0-out then
pass
endif
pass
endif
pass
endif
pass
endif
pass
endif
end-policy
route-policy CLIENTES_BGP_FULL
if destination in CLIENTES_BGP_FULL_PREFIXOS and extcommunity rt matches-any LP-10150-COMM then
set local-preference 10150
set community CUSTOMER_BGP_ALL additive
endif
if destination in CLIENTES_BGP_FULL_PREFIXOS and extcommunity rt matches-any LP-10190-COMM then
set local-preference 10190
endif
if destination in CLIENTES_BGP_FULL_PREFIXOS and extcommunity rt matches-any NO-EXPORT-COMM then
set community (no-export)
endif
if destination in CLIENTES_BGP_FULL_PREFIXOS and destination in BLACKHOLE_HOST_ROUTES and extcommunity rt matches-any BLACKHOLE_COMMS then
set community BLACKHOLE_COMMS additive
set next-hop discard
endif
if destination in CLIENTES_BGP_FULL_PREFIXOS then
set local-preference 10000
endif
end-policy
route-policy CDN-FACEBOOK-V4-IN
if destination in CDN-FACEBOOK-V4-IN then
pass
set local-preference 800
endif
end-policy
route-policy CDN-FACEBOOK-V6-IN
if destination in CDN-FACEBOOK-V6-IN then
pass
endif
end-policy
route-policy CDN-FACEBOOK-V4-OUT
if destination in CDN-FACEBOOK-V4-OUT then
pass
endif
end-policy
route-policy CDN-FACEBOOK-V6-OUT
if destination in CDN-FACEBOOK-V6-OUT then
pass
endif
end-policy
router static
10.0.0.0/8 xxxxxx.37.14 description ROTA-DE-RETORNO
XXX.XXX.68.0/22 xxxxxx.37.14 description Bloco_1
XXX.XXX.68.0/23 xxxxxx.37.14
XXX.XXX.68.0/24 xxxxxx.37.14
XXX.XXX.68.0/25 xxxxxx.37.14
XXX.XXX.68.128/25 xxxxxx.37.14
XXX.XXX.68.140/30 xxxxxx.37.14
XXX.XXX.69.0/24 xxxxxx.37.14
XXX.XXX.69.0/25 xxxxxx.37.14
XXX.XXX.69.128/25 xxxxxx.37.14
XXX.XXX.70.0/23 xxxxxx.37.14
XXX.XXX.70.0/24 xxxxxx.37.14
XXX.XXX.70.0/25 xxxxxx.37.14
XXX.XXX.70.128/25 xxxxxx.37.14
XXX.XXX.71.0/24 xxxxxx.37.14
XXX.XXX.71.0/25 xxxxxx.37.14
XXX.XXX.71.128/25 xxxxxx.37.14
xxxxxx.36.0/22 xxxxxx.37.14 description Bloco_2
xxxxxx.36.0/23 xxxxxx.37.14
xxxxxx.36.0/24 xxxxxx.37.14
xxxxxx.36.0/25 xxxxxx.37.14
xxxxxx.36.128/25 xxxxxx.37.14
xxxxxx.36.192/26 XXX.XXX.79.34.94 description CDN-FACEBOOK
xxxxxx.37.0/24 xxxxxx.37.14
xxxxxx.37.0/25 xxxxxx.37.14
xxxxxx.37.128/25 xxxxxx.37.14
xxxxxx.38.0/23 xxxxxx.37.14
xxxxxx.38.0/24 xxxxxx.37.14
xxxxxx.38.0/25 xxxxxx.37.14
xxxxxx.38.128/25 xxxxxx.37.14
xxxxxx.39.0/24 xxxxxx.37.14
xxxxxx.39.0/25 xxxxxx.37.14
xxxxxx.39.128/25 xxxxxx.37.14
XXX.XXX.79.32.0/22 xxxxxx.37.14 description Bloco_3
XXX.XXX.79.32.0/23 xxxxxx.37.14
XXX.XXX.79.32.0/24 xxxxxx.37.14
XXX.XXX.79.32.0/25 xxxxxx.37.14
XXX.XXX.79.32.128/25 xxxxxx.37.14
XXX.XXX.79.33.0/24 xxxxxx.37.14
XXX.XXX.79.33.0/25 xxxxxx.37.14
XXX.XXX.79.33.128/25 xxxxxx.37.14
XXX.XXX.79.34.0/23 xxxxxx.37.14
XXX.XXX.79.34.0/24 xxxxxx.37.14
XXX.XXX.79.34.0/25 xxxxxx.37.14
XXX.XXX.79.34.128/25 xxxxxx.37.14
XXX.XXX.79.35.0/24 xxxxxx.37.14
XXX.XXX.79.35.0/25 xxxxxx.37.14
XXX.XXX.79.35.128/25 xxxxxx.37.14
177.53.146.45/32 xxx.196.52.37 description Gateway-OPERATOR LOCAL 6GBPS
address-family ipv6 unicast
XXX:XXX:e94::/128 XXX:XXX:e94:1:f:: description GW_V6_OPERATOR LOCAL 6GBPS
XXX:XXX:2728::/32 XXX:XXX:2728:0:1::2 description Bloco_V6
XXX:XXX:2728::/33 XXX:XXX:2728:0:1::2 description Bloco_V6
XXX:XXX:2728:8000::/33 XXX:XXX:2728:0:1::2 description Bloco_V6
XXX:XXX:2728:face:b00c::/64 XXX:XXX:2728:face::1 description CDN_FACEBOOK_V6
snmp-server traps isis all
snmp-server traps ospfv3 errors bad-packet
snmp-server traps ospfv3 errors config-error
snmp-server traps ospfv3 errors virt-bad-packet
snmp-server traps ospfv3 errors virt-config-error
snmp-server traps ospfv3 state-change if-state-change
snmp-server traps ospfv3 state-change neighbor-state-change
snmp-server traps ospfv3 state-change nssa-state-change
snmp-server traps ospfv3 state-change virtif-state-change
snmp-server traps ospfv3 state-change virtneighbor-state-change
snmp-server traps ospfv3 state-change restart-status-change
snmp-server traps ospfv3 state-change restart-helper-status-change
snmp-server traps ospfv3 state-change restart-virtual-helper-status-change
router ospf MY-ISP_OSPF
router-id xxxxxx.36.1
default-information originate always metric-type 1
area 0.0.0.0
network point-to-point
snmp-server traps bgp cbgp2
router bgp XXX:XXX
bgp router-id xxxxxx.36.1
bgp attribute-download
network XXX.XXX.68.0/22
network XXX.XXX.68.0/23
network XXX.XXX.68.0/24
network XXX.XXX.68.0/25
network XXX.XXX.68.0/30
network XXX.XXX.68.128/25
network XXX.XXX.69.0/24
network XXX.XXX.69.0/25
network XXX.XXX.69.128/25
network XXX.XXX.70.0/23
network XXX.XXX.70.0/24
network XXX.XXX.70.0/25
network XXX.XXX.70.128/25
network XXX.XXX.71.0/24
network XXX.XXX.71.0/25
network XXX.XXX.71.128/25
network xxxxxx.36.0/22
network xxxxxx.36.0/23
network xxxxxx.36.0/24
network xxxxxx.36.0/25
network xxxxxx.36.128/25
network xxxxxx.37.0/24
network xxxxxx.37.0/25
network xxxxxx.37.128/25
network xxxxxx.38.0/23
network xxxxxx.38.0/24
network xxxxxx.38.0/25
network xxxxxx.38.128/25
network xxxxxx.39.0/24
network xxxxxx.39.0/25
network xxxxxx.39.128/25
network XXX.XXX.79.32.0/22
network XXX.XXX.79.32.0/23
network XXX.XXX.79.32.0/24
network XXX.XXX.79.32.0/25
network XXX.XXX.79.32.128/25
network XXX.XXX.79.33.0/24
network XXX.XXX.79.33.0/25
network XXX.XXX.79.33.128/25
network XXX.XXX.79.34.0/23
network XXX.XXX.79.34.0/24
network XXX.XXX.79.34.0/25
network XXX.XXX.79.34.128/25
network XXX.XXX.79.35.0/24
network XXX.XXX.79.35.0/25
network XXX.XXX.79.35.128/25
network XXX:XXX:2728::/32
network XXX:XXX:2728::/33
network XXX:XXX:2728:8000::/33
neighbor-group IX.br-IPv4
remote-as 26162
enforce-first-as disable
route-policy PTT-SP-V4-OUT out
neighbor-group IX.br-IPv6
remote-as 26162
route-policy PTT-V6-OUT out
neighbor XXX:XXX:e94::
remote-as 262468
ebgp-multihop 10
description OPERATOR LOCAL 6GBPS-V6
route-policy OPERATOR LOCAL 6GBPS-V6-IN in
route-policy OPERATOR LOCAL 6GBPS-V6-OUT out
remove-private-AS
neighbor xxxxxx.36.6
remote-as 40027
description NETFLIX-V4
update-source Bundle-Ether2.10
route-policy NETFLIX-V4-IN in
route-policy NETFLIX-V4-OUT out
remove-private-AS
neighbor XXX.XXX.79.33.30
remote-as 11344
password encrypted 097B4B1B1F13151A1E050B
description GGC-V4
update-source Bundle-Ether2.11
route-policy GGC-V4-IN in
route-policy GGC-V4-OUT out
remove-private-AS
neighbor 187.16.220.8
remote-as 20940
description AKAMAI-V4
update-source Bundle-Ether1.902
route-policy PTT-SP-V4-IN in
remove-private-AS
neighbor XXX.XXX.68.33
remote-as XXX:XXX
shutdown
description BRAS-PPPOE-DC-PE
update-source Loopback0
next-hop-self
neighbor 177.53.146.45
remote-as 262468
ebgp-multihop 10
description OPERATOR LOCAL 6GBPS-V4
route-policy OPERATOR LOCAL 6GBPS-V4-IN in
route-policy OPERATOR LOCAL 6GBPS-V4-OUT out
remove-private-AS
neighbor 177.84.162.13
remote-as 262589
shutdown
description INTERNEXA-V4
update-source Bundle-Ether1.2425
route-policy INTERNEXA-V4-IN in
route-policy INTERNEXA-V4-OUT out
remove-private-AS
neighbor 187.16.216.55
remote-as 15169
password encrypted 020C114F19070176486B0B2C1205440855
description Google-1
remove-private-AS
neighbor 187.16.216.68
remote-as 6507
description RioGames1-V4
remove-private-AS
neighbor 187.16.218.58
remote-as 15169
password encrypted 11030C110513055B000F29113F2163214A
description Google-2
remove-private-AS
neighbor 187.16.218.82
remote-as 32934
shutdown
description FACEBOOK1-V4
remove-private-AS
neighbor 187.16.222.60
remote-as 32934
shutdown
description FACEBOOK4-V4
remove-private-AS
neighbor 187.16.222.61
remote-as 32934
shutdown
description FACEBOOK3-V4
remove-private-AS
neighbor 2001:12f8::55
remote-as 15169
password encrypted 030E4E1F140E2F1B4A2C1B3000005D0F5D
description GOOGLE-1-V6
update-source Bundle-Ether1.903
route-policy PTT-V6-IN in
remove-private-AS
neighbor XXX.XXX.68.142
remote-as 266476
ebgp-multihop 10
description GA-V4
update-source Bundle-Ether2.1100
route-policy GA-V4-IN in
route-policy GA-V4-OUT out
next-hop-self
remove-private-AS
neighbor xxxxxx.36.208
remote-as 63293
ebgp-multihop 10
description CDN-FACEBOOK-V4
update-source Bundle-Ether2.12
route-policy CDN-FACEBOOK-V4-IN in
route-policy CDN-FACEBOOK-V4-OUT out
remove-private-AS
neighbor 178.248.237.29
remote-as 197068
ebgp-multihop 255
password encrypted 15585955072E000B796576
description BGP-QRATOR
route-policy DISCARD_ALL out
remove-private-AS
neighbor 187.16.216.252
remote-as 20121
description PTT-SP-LG-V4
remove-private-AS
neighbor 187.16.216.253
remote-as 26162
use neighbor-group IX.br-IPv4
description PTT-SP-RS1-V4
remove-private-AS
neighbor 187.16.216.254
remote-as 26162
description PTT-SP-RS2-V4
remove-private-AS
neighbor 187.16.218.139
remote-as 8075
shutdown
description MICROSOFT-V4
remove-private-AS
neighbor 187.16.218.144
remote-as 8075
shutdown
description MICROSOFT1-V4
remove-private-AS
neighbor 187.16.219.111
remote-as 13335
shutdown
description CLOUDFLARE-V4
remove-private-AS
neighbor 187.16.220.140
remote-as 14413
shutdown
description LINKEDIN-V4
remove-private-AS
neighbor 187.16.220.240
remote-as 32934
shutdown
description FACEBOOK2-V4
remove-private-AS
neighbor 187.16.221.243
remote-as 46489
shutdown
description TWITCH1-V4
remove-private-AS
neighbor 187.16.221.244
remote-as 46489
shutdown
description TWITCH2-V4
remove-private-AS
neighbor 187.16.223.253
remote-as 26162
description PTT-SP-RS3-V4
remove-private-AS
neighbor 187.16.223.254
remote-as 26162
description PTT-SP-RS4-V4
remove-private-AS
neighbor 2001:12f8::253
remote-as 26162
use neighbor-group IX.br-IPv6
remove-private-AS
neighbor 2001:12f8::254
remote-as 26162
remove-private-AS
neighbor 2001:12f8::218:58
remote-as 15169
password encrypted 070534585C0817521337093913387D2771
remove-private-AS
neighbor XXX:XXX:680:14:a::b1
remote-as 262589
shutdown
description INTERNEXA-V6
route-policy INTERNEXA-V6-IN in
route-policy INTERNEXA-V6-OUT out
remove-private-AS
neighbor 2001:12f8::218:139
remote-as 8075
shutdown
description MICROSOFT-1-V6
remove-private-AS
neighbor 2001:12f8::218:144
remote-as 8075
shutdown
description MICROSOFT-2-V6
remove-private-AS
neighbor 2001:12f8::219:111
remote-as 13335
shutdown
description CloudFlare-V6
remove-private-AS
neighbor 2001:12f8::220:140
remote-as 14413
shutdown
description LinKedin-V6
remove-private-AS
neighbor 2001:12f8::220:240
remote-as 32934
description FACEBOOK-V6
remove-private-AS
neighbor 2001:12f8::221:243
remote-as 46489
shutdown
description Twitch-1-V6
remove-private-AS
neighbor 2001:12f8::221:244
remote-as 46489
shutdown
description Twitch-2-V6
remove-private-AS
neighbor 2001:12f8::223:253
remote-as 26162
description PTT-SP-RS1-V6
remove-private-AS
neighbor 2001:12f8::223:254
remote-as 26162
description PTT-SP-RS2-V6
remove-private-AS
neighbor XXX:XXX:2728:1000:2::3
remote-as 40027
description CDN-NETFLIX-V6
remove-private-AS
neighbor XXX:XXX:2728:1000:3::fffe
remote-as 11344
password encrypted 122E0005141D0E0C3F222B
description GGC-V6
remove-private-AS
neighbor XXX:XXX:2728:face:b00c::10
remote-as 63293
ebgp-multihop 10
description CDN-FACEBOOK-V6
route-policy CDN-FACEBOOK-V6-IN in
route-policy CDN-FACEBOOK-V6-OUT out
remove-private-AS
snmp-server traps vpls status
ssh server dscp 63
ssh server v2
ssh server vrf default
ssh timeout 120
snmp-server traps ospf lsa lsa-maxage
snmp-server traps ospf lsa lsa-originate
snmp-server traps ospf errors bad-packet
snmp-server traps ospf errors authentication-failure
snmp-server traps ospf errors config-error
snmp-server traps ospf errors virt-bad-packet
snmp-server traps ospf errors virt-authentication-failure
snmp-server traps ospf errors virt-config-error
snmp-server traps ospf retransmit packets
snmp-server traps ospf retransmit virt-packets
snmp-server traps ospf state-change if-state-change
snmp-server traps ospf state-change neighbor-state-change
snmp-server traps ospf state-change virtif-state-change
snmp-server traps ospf state-change virtneighbor-state-change
end
Georg Pauwen
are all three carriers active at the same time ? I don't see any BGP fast failover configured, so you might just be running intp BGP convergence.
You also have soft reconfiguration configured, that shouldn't be necessary and just increases the memory load.
That said, if your three carriers are active at the same time, have you considered unequal cost multipath load balancing ?
the 3 carriers are active. the problem is if PTT is left out or internexa, out of nowhere the traffic of the local carrier drops to less than 1gbps and until we are not navigated within the company and after 20 minutes the traffic in it goes back up to normal. What can I do to solve it?
