Convert config from XE to XR
Channels
Hello everyone,
I read about this community that it was possible to convert a Cisco IOS XE configuration to Cisco XR?
I have a small classic configuration with interfaces, ospf, bgp, route-map, tunnel, one vrf and NAT ...
I plan to change my ASR 1002 to 9001.
Thank you for your answers.
julian.bendix
Hi!
I heard that there is an Cisco-internal Tool which is meant for basically translating IOS Config to IOS-XR Config which is "commitable" but maybe not really fully correct.
But to my knowledge this is totally not available for public.
Only way I know of is opening a TAC Case,
or (of course) configure the ASR9k by yourself.
Best regards
Julian
Thank you Julian for your answer.
Would you tell me if I have the right to open a Cisco TAC with my simple account without any special support / access?
If yes, how ?
Hi!
No I don't think you can open a TAC Case then,
but as also suggested from Georg in the Comment below:
If you have the time to configure the ASR9k before going productive step-by-step,
we could manage to translate the config here :)
Best regards
Julian
post the configuration here and let us have a go at it...
