After a recent Chassis change on our dear 7507 router (using RSP-16), we observed that following command started failing for slavecs7:
ITP#cs7 save route-table disk0:/route_20080905.txt
Route-table 'system' saved to 'disk0:/route_20080905.txt'
Copying 'disk0:/route_20080905.txt' to secondary processor
Error: Copy of cs7:route-tables/system to slavecs7:route-tables/system failed.
Issue stays even if i do an IOS upgrade.
What I need?
Ans: A procedure to correct this behavior.
I might have to format slavedisk0:, but will a 'format slavedisk0:' get me the original filesystem back and working. Right now the filesystem looks like the one i have attached.
If a format is what I need, then... what all files do i need to replenish on this new slavedisk0: to make it working.
can i move these files from disk0: to slavedisk0: or should i backup the one present on slavedisk0:
I am using SSO mode of redundancy on this device.
Let me know if you need any more info to help me with this case.
