Could I use "vlan interface" as a tunnel source of DMVPN ?
Hung Tsung Chen
I have a router R2811 with a 9 port FE Switch module(HWIC-D-9ESW).
Could I use vlan interface as a tunnel source when configuring DMVPN ?
The vlan ports is on the 9 port FE Switch module.
Because it's used now in production,I can't try it.
Hello.
I think there is no restriction on software routers like 2811.
PS: using loopback could be a better idea.
Ruben Cocheno
hello,
you can use the specific IP of that interface vlan
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
