Could the Cisco router do return NAT?
My configuration looks like:
interface GigabitEthernet0/0
 description External
 ip address x.223.40.119 255.255.255.0
 ip nat enable
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description Internal
 ip address x.100.1.253 255.255.255.0
 ip nat enable
 duplex auto
 speed auto
ip nat source static x.100.1.202 x.223.40.154
ip nat source static x.100.1.204 x.223.40.155
The x.100.1.202 can't ping & rdp to x.223.40.155. How should I do?
9 Replies 9
omz
Under the interface config you need - ip nat inside / ip nat outside command on the appropriate interface.
See example -
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/13773-2.html
My configuration now looks like:
 ip nat outside
 duplex auto
 speed auto
 ip nat inside
 duplex auto
 speed auto
ip nat inside source static x.100.1.202 x.223.40.154
ip nat inside source static x.100.1.204 x.223.40.155
The x.100.1.202 can ping but can't rdp to x.223.40.155.
I tried to add more 2 commands:
ip nat outside source static x.223.40.154 x.100.1.202
ip nat outside source static x.223.40.155 x.100.1.204
Thank you very much.
Hello
Externally you should be able to ping towards  x.223.40.154 and see a translation to x.100.1.202  and the same goes for  x.223.40.155 and see a translation to x.100.1.204
Internally you should be able to ping anything internal without nat being introduced.
Now if are you wishing to connect to the external natted address of an internal host from another internal host?
Then were correct in the first place to use domian-less nat (ip nat enable,  ip nat source static xx)  and it should have worked
Can you post the configuration of your rtr, Do you have a default applied?
Kind Regards
Paul
The configuration in the topic and I also attach of the whole router.
# sho ip nat nvi tra icmp
Pro Source global         Source local          Destin  local         Destin  global
icmp x.170.119.58:39556 x.170.119.58:39556  x.223.40.155:39556  x.100.1.204:39556
icmp x.170.119.58:44676 x.170.119.58:44676  x.223.40.154:44676  x.100.1.202:44676
icmp x.223.40.154:1     x.100.1.202:1        x.223.40.155:1      x.100.1.204:1
Hello
Your nat configuration seems correct.
It could be something else that is negating response between these hosts from natted address.
On host x.100.1.202 does it have a default-gateway towards the nat router, any software fw etc..
Kind Regards
Paul
How should I do?
Hello
Can you turn off any software fw on those hosts please, Also clear arp from the rtr and the hosts and test again.
Kind Regards
Paul
The x.100.1.202 can't ping & rdp to x.223.40.155. However, x.100.1.202 can ping & rdp to x.100.1.204 and external (another public subnet) also can ping & rdp to x.223.40.155 normally.
Hello
As I said something else is negating this access and for you to confirm it was working suggests a change has occurred so now to prohibit connection.
What is sitting behind the lan interface of the nat rtr where these host are located?
Kind Regards
Paul
