06-24-2025 07:06 PM - edited 06-24-2025 07:10 PM
Experts,
Need your pick your brain on this issue. So I have 3 routers(iosv-3, iosv6 and iosv4) and a layer 2 switch(iol-l2-1). I'm using iosv-4 router as a multicast receiver by using the command ip igmp join-group 239.1.1.1. My goal is to ping 239.1.1.1 from iosv-3. I can ping the iosv-4 from iosv-3 using the unicast address but not with the multicast address.
At this time, iosv-6 has a sub interface of gi0/1.2 where the iosv-4 is in the vlan 2. When I don't have the sub interface, just the physical interface , i can ping the multicast address but not when I have the sub interface though. When I did the packet capture, i see the ICMP packets from iosv-3 to iosv-6. But I don't packets leaving from iosv-6 to the iosv-4.
Is there any command I have to enable when I use the sub interfaces?
Here is the "show ip mroute" on the iosv-6 router.
Here is the ip config on the iosv-6 router
Config on the iosv-4
Config on the iosv-3
Solved! Go to Solution.
06-24-2025 11:04 PM
Hello @paheeradan.nagulan
Since you are using pim sparse-mode, where is your rendez-vous point on your topology ? Configured on each routers also ?
06-25-2025 06:33 AM - edited 06-25-2025 06:50 AM
Add ip pim sparse-mode command on iosv-4 under interface Gi0/0 interface
interface GigabitEthernet0/0
ip address 2.0.0.1 255.255.0.0
ip pim sparse-mode
Ensure that IGMP snooping is configured on L2 switch too
Esure that ip pim sparse-mode command is also configured on iosv-6 interface Gi0/1
Ensure that iosv-4 has got default route towards 2.0.0.2
06-25-2025 06:55 AM - edited 06-25-2025 06:56 AM
Also ensure that Lo 3.3.3.3 has got ip pim sparse-mode command too...
That should suceed after that:
06-25-2025 07:06 AM - edited 06-25-2025 07:07 AM
yes for L2 Switch!
On iosv-6 shluld be SJCL flag !
On L2 switch do you configured ip multicast-routing command ?
06-25-2025 08:15 AM - edited 06-25-2025 08:23 AM
ip igmp snooping is activated on your L2 Switch ?
06-25-2025 08:38 AM
iosv-4 can ping 3.3.3.3 ? Please check this.
06-26-2025 02:28 AM - edited 06-26-2025 02:29 AM
hello @paheeradan.nagulan
please provide the output of that command on iosv-3, iosv-4 and iosv-6
#show ip pim tunnel
Thanks a lot.
06-26-2025 07:25 AM
Thanks @paheeradan.nagulan
OK for iosv-4 but it still is a router, so add ip multicast-routing command under config terminal and ip pim sparse-mode on Gig0/0
06-26-2025 08:02 AM - edited 06-26-2025 08:03 AM
Perfect what I see on screenshoot.
Please provide a screenshoot of your icmp from iosv-3
06-26-2025 08:44 AM - edited 06-26-2025 08:49 AM
Hi @paheeradan.nagulan ,
Since you can successfully ping 239.1.1.1 when you do not use a subinterface, it appears that your multicast configuration is correct.
The issue is that iosv-6 does not receive the igmp membership report from iosv-4. You could verify this with the following command on iosv-6: "show ip igmp groups".
This is most probably due to igmp snooping being configured on iol-l2-1.
I would suggest you try disabling igmp snooping on iol-l2-1 (no ip igmp snooping) and then verify that igmp membership report is properly received on iosv-6.
If so you should be able to successfully ping 239.1.1.1 from iosv-3.
06-26-2025 09:13 AM
Hi @Harold Ritter ,
Right on. Once I disabled igmp snooping on the switch, I saw the entry for 239.1.1.1 on the IOSV-6 switch under "ip igmp groups". Then I was able to ping the multicast address from iosv-3 to iosv-4. Thanks again for that thought. Appreciate it.
The part I don't get is, when I had "igmp snooping enabled" on the switch, I was doing a packet capture between iosv-6 and the switch and I saw the packet for the igmp join message from the iosv-4. Still I didn't see the entry for the multicast for 239.1.1.1 though under "ip igmp groups". What could be the reason for that?
06-26-2025 10:14 AM - edited 06-26-2025 10:23 AM
> I was doing a packet capture between iosv-6 and the switch and > I saw the packet for the igmp join message from the iosv-4.
If you still have the packet capture file, you will probably see that the igmp membership report with destination address of 239.1.1.1 is being forwarded untagged towards iosv-6, despite the igmp membership query being received as tagged (vlan 2). This is why iosv-6 doesn't receive it properly.
This is most probably some sort of bug on the IOL L2 code.
06-24-2025 11:04 PM
06-25-2025 06:15 AM
The rp address is the loopback of isov-6 router. I made sure that iosv-3 can ping that ip address.
Here is the output from iosv-3
ip pim sparse-mode
06-25-2025 05:30 AM
Hey there—when you move your multicast VLAN onto a router sub-interface you have to remember that multicast isn’t on by default the way unicast is
Here’s what you need to do:
Enable multicast routing globally so the router will forward multicast traffic:
iosv-6(config)# ip multicast-routing
Configure your VLAN 2 sub-interface for multicast:
iosv-6(config)# interface GigabitEthernet0/1.2
iosv-6(config-if)# encapsulation dot1Q 2
iosv-6(config-if)# ip address 2.0.0.2 255.0.0.0
iosv-6(config-if)# ip pim sparse-mode
This tags the interface for VLAN 2, assigns an IP, and enables PIM sparse-mode.
Verify or adjust IGMP snooping on your switch:
After that, you can confirm everything is working by running:
show ip mroute
You should see your multicast group entries, and you’ll be able to ping 239.1.1.1 from iosv-3 through iosv-6 to iosv-4.
Hope that helps—feel free to give it a try and let me know how it goes.
06-25-2025 06:41 AM - edited 06-25-2025 06:42 AM
Hi @wajidhassan ,
I added those config and still not able to ping across.
Here is the config on iosv-6
On the switch, the router interface is acting as the querier for the vlan 2.
After pinging from iosv-3 to iosv4(239.1.1.1), Here is the show ip mroute on the iosv-6
I see "SPF" flags for the entry ( *, 239.1.1.1). Is that supposed to be like that?
yes for L2 Switch!
06-25-2025 07:54 AM
Not sure why I am seeing SPF flag then!!!! Regarding the l2 switch, since it's a layer 2 . do you think I need to enable multicast routing on that?
06-25-2025 09:52 AM
Yes, igmp snooping enabled on the switch. iosv-4 can ping the iosv-3 device.
#show ip pim tunnel
Thanks a lot.
06-26-2025 07:02 AM - edited 06-26-2025 07:09 AM
Hi M02@rt37,
Here is the output on IOSV-3
Output on IOSV-6
On Iosv-4, I just added the config "ip igmp join-group 239.1.1.1"(Make it a multicast receiver) So there is no pim tunnel on that! isov-4 can ping 3.3.3.3.
06-26-2025 07:25 AM
06-26-2025 07:50 AM
I added the config.
Still I couldn't ping the multicast address of 239.1.1.2 from iosv-3
