couldn't ping through source interface
rahul.bambhnia
Community Member
Dear all,
Can anyone help me to resolve my problem.below is sh run of all router in which router R1, R2,R3,R4 communicate with each other its ok but when i trying to ping to router R1 from R4's source interface f0/0 then its not getting pinging but if i do normal ping from R4 to R1 then it pinging.
similarly for R3 also but over here i have mention sh run of R1 R2 R4 only.
even i have add static route in R1 towards R4 but i can't.
R4#ping 10.1.1.1
Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/33/84 ms
R4#ping 10.1.1.1 source f0/0
Packet sent with a source address of 172.41.1.1
Success rate is 0 percent (0/5)
R1#sh run
Building configuration...
*Sep 1 11:20:11.163: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 2048 bytes
! Last configuration change at 11:20:11 UTC Thu Sep 1 2016
version 12.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
ip tcp synwait-time 5
interface Loopback4
ip address 10.1.1.1 255.255.255.0
interface Loopback5
ip address 10.1.2.1 255.255.255.0
interface Loopback6
ip address 10.1.3.1 255.255.255.0
interface Loopback7
ip address 10.1.4.1 255.255.255.0
interface Loopback8
ip address 10.1.5.1 255.255.255.0
interface Loopback9
ip address 10.1.6.1 255.255.255.0
interface Loopback10
ip address 10.1.7.1 255.255.255.0
interface Serial2/0
ip address 172.12.1.2 255.255.255.0
serial restart-delay 0
router rip
version 2
network 10.0.0.0
network 172.12.0.0
no auto-summary
no ip http server
no ip http secure-server
ip route 172.41.0.0 255.255.255.0 Serial2/0
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2
R2#sh run
Current configuration : 2163 bytes
version 12.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
no ip domain lookup
ip cef
no ipv6 cef
interface FastEthernet0/0
no ip address
shutdown
interface Serial2/0
ip address 172.12.1.1 255.255.255.0
interface Serial2/1
ip address 172.23.1.1 255.255.255.0
interface Serial2/2
ip address 172.24.1.1 255.255.255.0
router ospf 1
log-adjacency-changes
redistribute rip metric 1000 subnets route-map rahul
network 172.0.0.0 0.255.255.255 area 0
router rip
version 2
redistribute ospf 1 metric 12 route-map pooja
network 172.12.0.0
no auto-summary
no ip http server
access-list 5 permit 10.1.1.0 0.0.0.255
access-list 5 permit 10.1.2.0 0.0.0.255
access-list 5 permit 10.1.3.0 0.0.0.255
access-list 10 permit 172.30.1.0 0.0.0.255
access-list 10 permit 172.30.2.0 0.0.0.255
access-list 10 permit 172.30.3.0 0.0.0.255
route-map rahul permit 10
match ip address 5
set metric 2000
route-map rahul permit 20
route-map pooja permit 10
match ip address 10
set metric 15
route-map pooja permit 20
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R4
R4#sh run
Current configuration : 1512 bytes
version 12.2
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
no ip domain lookup
ip cef
no ipv6 cef
ip address 172.41.1.1 255.255.255.0
duplex half
interface Ethernet1/0
no ip address
shutdown
duplex half
interface Serial2/0
ip address 172.24.1.2 255.255.255.0
no ip http server
ip route 0.0.0.0 0.0.0.0 172.24.1.1
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Pawan Raut
Level 10
Level 10
R1 dont have route For R4 F0/0 that is 172.41.1.1
Add below route on R1 and R2
R1
ip route 172.41.1.0 255.255.255.0 Serial2/0
R2
ip route 172.41.1.0 255.255.255.0 Serial2/2
6 Replies 6
Terence Payet
Level 6
Level 6
You need to advertise your network currently configured on fa0/0 on R4 to other routers for you to be able to ping.
Enable RIP and advertise your network accordingly:
router rip
ver 2
network 172.41.0.0
no auto
HTH.
Please rate helpful post.
Terence
Thanks Terence,
But i don't want to use dynamic routing between R2 & R4 so is that any other way to do this.
R1
R2
You can use static route as suggested by pawan.raut.
But you will need to do some redistribution on R2 in order for R2 to communicate with R4.
HTH.
Terence
Pawan Raut
Level 10
Level 10
R1
R2
rahul.bambhnia
Community Member
Dear Pawan,
Thank you so much actually i was forgot to add route in R2.
thanks so much again.
