CPU load on ISR G2
abarakat77
I have a cisco 2900 ISR G2 with a high cpu load and with the command "sh processes cpu sorted", I can't figure which process is the cause
If we look this example, the load is about 25% but the load total of process is around 2%...
CPU utilization for five seconds: 26%/24%; one minute: 23%; five minutes: 25%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
189       31112  1197414086          0  0.39%  0.35%  0.34%   0 HQF Output Shape
326       77808   346608032          0  0.39%  0.34%  0.32%   0 HSRP Common
120     9406884   308648542         30  0.31%  0.33%  0.30%   0 IP Input
   3        1592         928       1715  0.15%  0.24%  0.12% 388 SSH Process
128       23956   653917473          0  0.15%  0.20%  0.21%   0 Ethernet Msec Ti
342     3340332    58413774         57  0.15%  0.12%  0.13%   0 OSPF-100 Hello
327     2882656   152727925         18  0.07%  0.07%  0.07%   0 HSRP IPv4
166       19060   149926818          0  0.07%  0.04%  0.05%   0 IPAM Manager
  85       33800     4806733          7  0.07%  0.10%  0.08%   0 Per-Second Jobs
117       11952     9610784          1  0.07%  0.02%  0.01%   0 BPSM stat Proces
122       24040     4801629          5  0.07%  0.00%  0.00%   0 FHRP Main thread
328       13148     4693011          2  0.07%  0.04%  0.05%   0 CFT Timer Proces
  33        1916     5008163          0  0.07%  0.00%  0.00%   0 ARP Background
  13     3438280       80038      42958  0.00%  0.07%  0.05%   0 Licensing Auto U
Maybe I have missed to look something ?
Thanks for any tips
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Usually.  In your case, 24% is interrupt CPU and 2% is other process CPU.  Interrupt CPU within 2 to 4 percent of total CPU is generally good.
What you might check, is whether the interrupt CPU appears to corresponds to the total traffic passing through your router and rough match that router's documented PPS (packets per second) rate.  If the PPS rate seems abnormally low, you might have packets causing extra forwarding load.  It can be difficult to identify cause for this as we don't have much visibility into "interrupt" forwarding.
Joseph W. Doherty
Disclaimer
Posting
The bulk of your CPU is "interrupt" CPU which normally is the CPU load for forwarding "normal" traffic.
Thanks joseph
so the remaining cpu use is for forwarding process right ?
Disclaimer
Posting
