cpu to high
support.golan
Level 2
Level 2
good morning
i am useing cisco 1841 when i am looking on my router cpu usage is to high
can you explain me how can check it
              7    112     22          82     22   2                  9
    5         31 1306056468031         55  41234233341            1 1272 1
100        *   *
90                                    *                              *   *
80                                    *                              *   *
70           *                        *                              *   *
60           *                        *                              *   *
50           *                        *                              *   *
40           *                        *                              *   *
30           *                        **                             *   **
20           *     **     **          **     **   *                  *   **
10 *         *    *#*** ****          **     **   *                  *   **
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
                  * = maximum CPU%   # = average CPU%
can i see more detauls what is takeing those cpu usage
thanks golan
Ganesh Hariharan
good morning
              7    112     22          82     22   2                  9
100        *   *
90                                    *                              *   *
80                                    *                              *   *
70           *                        *                              *   *
60           *                        *                              *   *
50           *                        *                              *   *
40           *                        *                              *   *
30           *                        **                             *   **
thanks golan
Hi Golan,
Sh process cpu will show you the detail of process consumig high cpu and check out the below link for troubleshooting guid on high CPU on routers
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
thaks
please see my cpu results
CPU utilization for five seconds: 5%/4%; one minute: 1%; five minutes: 1%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1           0         4          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2        6816   1912314          3  0.00%  0.01%  0.00%   0 Load Meter
   3      618416   4635243        133  0.00%  0.00%  0.00%   0 Spanning Tree
   4     2674956    976766       2738  0.00%  0.03%  0.00%   0 Check heaps
   5           0        15          0  0.00%  0.00%  0.00%   0 Pool Manager
   6           0         2          0  0.00%  0.00%  0.00%   0 Timers
   7           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
   8          52    318720          0  0.00%  0.00%  0.00%   0 Environmental mo
   9           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  10      181660    875833        207  0.00%  0.00%  0.00%   0 ARP Input
  11           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  12           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  13           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  14           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  15           0         2          0  0.00%  0.00%  0.00%   0 DDR Timers
  16           4         2       2000  0.00%  0.00%  0.00%   0 Entity MIB API
  17         520    478079          1  0.00%  0.00%  0.00%   0 HC Counter Timer
  18           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  19           0         1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  20           0         2          0  0.00%  0.00%  0.00%   0 SMART
  21        1128   9561561          0  0.00%  0.00%  0.00%   0 GraphIt
  22           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  23           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  24           0         2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  25        2500  17816497          0  0.00%  0.00%  0.00%   0 IP NAT Ager
  26           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  27           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  28        2620   5353399          0  0.00%  0.00%  0.00%   0 Net Background
  29           0         2          0  0.00%  0.00%  0.00%   0 IDB Work
  30          56    282269          0  0.00%  0.00%  0.00%   0 Logger
  31        1300   9561507          0  0.00%  0.00%  0.00%   0 TTY Background
  32        4596   9561648          0  0.00%  0.01%  0.00%   0 Per-Second Jobs
  33           0         2          0  0.00%  0.00%  0.00%   0 AggMgr Process
  34         120        54       2222  0.00%  0.00%  0.00%   0 ESWPPM
  35           0         2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  37           0         1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  38           0         1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  39           0         2          0  0.00%  0.00%  0.00%   0 SM Monitor
  40         152       808        188  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
  41         168       827        203  0.00%  0.00%  0.00%   0 IGMP Snooping Re
  42           0         1          0  0.00%  0.00%  0.00%   0 Platform Compact
  43          16    318720          0  0.00%  0.00%  0.00%   0 Call Management
  44          28        41        682  0.00%  0.00%  0.00%   0 Switch Link Moni
  45         704   9561511          0  0.08%  0.00%  0.00%   0 PI MATM Aging Pr
  46           0         2          0  0.00%  0.00%  0.00%   0 DTP Protocol
  47           0        25          0  0.00%  0.00%  0.00%   0 dot1x
  48           0         1          0  0.00%  0.00%  0.00%   0 L2X Data Daemon
  49           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  50           0         2          0  0.00%  0.00%  0.00%   0 AAA Server
  51           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  52           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  53       76068   1471895         51  0.00%  0.00%  0.00%   0 CDP Protocol
  54      128036    476369        268  0.08%  0.04%  0.01%   0 IP Input
  55           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  56           0        14          0  0.00%  0.00%  0.00%   0 TurboACL
  57           0         2          0  0.00%  0.00%  0.00%   0 TurboACL chunk
  58          12     15922          0  0.00%  0.00%  0.00%   0 MOP Protocols
  59           0         3          0  0.00%  0.00%  0.00%   0 PPP Hooks
  60           0         1          0  0.00%  0.00%  0.00%   0 IP NAT WLAN
  61           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
  62          96   1274889          0  0.00%  0.00%  0.00%   0 SSS Test Client
  63           0         1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
  64        4488  37350198          0  0.08%  0.01%  0.00%   0 SSS Feature Time
  65           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
  66           0         1          0  0.00%  0.00%  0.00%   0 L2X Socket proce
  67           0         1          0  0.00%  0.00%  0.00%   0 L2X SSS manager
  68           0         2          0  0.00%  0.00%  0.00%   0 L2TP mgmt daemon
  69           4         1       4000  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
  70         784    313170          2  0.00%  0.00%  0.00%   0 IP Background
  71          60    159463          0  0.00%  0.00%  0.00%   0 IP RIB Update
  72           0         2          0  0.00%  0.00%  0.00%   0 PPP IP Route
  73           0         2          0  0.00%  0.00%  0.00%   0 PPP IPCP
  74        3988  14892145          0  0.08%  0.01%  0.00%   0 CEF process
  75        1452   9561557          0  0.00%  0.00%  0.00%   0 Socket Timers
  76           8       365         21  0.00%  0.00%  0.00%   0 L2MM
  77          72       810         88  0.00%  0.00%  0.00%   0 MRD
  78           4        20        200  0.00%  0.00%  0.00%   0 IGMPSN
  79           0         1          0  0.00%  0.00%  0.00%   0 SNMP Timers
  80           4         2       2000  0.00%  0.00%  0.00%   0 SCTP Main Proces
  81           0         1          0  0.00%  0.00%  0.00%   0 IUA Main Process
  82        1904   9561634          0  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
  83           0         1          0  0.00%  0.00%  0.00%   0 bsm_timers
  84         508   9561616          0  0.00%  0.00%  0.00%   0 bsm_xmt_proc
  85        1948     66953         29  0.00%  0.00%  0.00%   0 TCP Timer
  86         320       430        744  0.00%  0.00%  0.00%   0 TCP Protocols
  87           0         1          0  0.00%  0.00%  0.00%   0 COPS
  88       11904  19123116          0  0.08%  0.04%  0.06%   0 DHCPD Receive
  89           0         2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
  90           4    159362          0  0.00%  0.00%  0.00%   0 IP Cache Ager
  91         380    159372          2  0.00%  0.00%  0.00%   0 Adj Manager
  92           0     31874          0  0.00%  0.00%  0.00%   0 HTTP CORE
  93           0         1          0  0.00%  0.00%  0.00%   0 IP Traceroute
  94           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
  95           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
  96           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
  97           0         2          0  0.00%  0.00%  0.00%   0 PPP Bind
  98           0         2          0  0.00%  0.00%  0.00%   0 PPP SSS
  99          36    382468          0  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
100           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
101           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr
102           0         1          0  0.00%  0.00%  0.00%   0 Key chain liveke
103           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
104           0         2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
105           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
106         744   4465130          0  0.00%  0.00%  0.00%   0 PM Callback
107          12     79681          0  0.00%  0.00%  0.00%   0 DHCPD Timer
108           0         2          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
109        3624    191119         18  0.24%  0.09%  0.07% 194 Virtual Exec
110          92    956168          0  0.00%  0.00%  0.00%   0 RMON Recycle Pro
111           0         2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
112           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
113           8         2       4000  0.00%  0.00%  0.00%   0 VLAN Manager
114           8     13036          0  0.00%  0.00%  0.00%   0 Syslog
115           0         1          0  0.00%  0.00%  0.00%   0 VPDN Scal
116           4    159367          0  0.00%  0.00%  0.00%   0 DHCPD Database
117       41976    627882         66  0.00%  0.00%  0.00%   0 Net Input
118        2448   1912387          1  0.00%  0.00%  0.00%   0 Compute load avg
119     1280664    159475       8030  0.00%  0.01%  0.00%   0 Per-minute Jobs
120         148    331616          0  0.00%  0.00%  0.00%   0 CEF Scanner
121           0         1          0  0.00%  0.00%  0.00%   0 tHUB
122           0         2          0  0.00%  0.00%  0.00%   0 tENM
podhillo
Level 4
Level 4
Hi Golan,
This is not a HIGH CPU case.
The device is in HIGH CPU usage only when the '#' signs average upto a percentage.
eg:
                 7    112     22          82     22   2                  9
100        *   *
90                                    *                              *   *
80                                    *                              *   *
70           *                        *                              *   *
60           *                        *                              *   *
50           *                        *                              *   *
40           *                        *                              *   *
30           *                        **                             *   **
10 ###############################################
The above example shows that the CPU utilization for the device is at an average of 10 percent, the ' * ' means we had a occasional spikes due to a few process which consume cpu for a instance.
Please let me know if this was helpful.
podhillo
