Enabling SSH
dj214
Level 3
Level 3
Hi - I need to implement SSH on 2 3600 series roouters running IOS 12.3(9). I read a few Cisco articles and although it looks easy. I cannot get it working. The commands do not work that are int h e DOC.
Can someone let me know how this is done or disable SSH altogether
7 Replies 7
Giuseppe Larosa
Hello DJ Stanley,
support of SSH depends on the specific feature set the IOS image is part of
if you post
sh ver | inc image
it will be possible to check if SSH is supported on your current IOS image
Hope to help
Giuseppe
Hi Stanley
To enable SSH on router you can run the below command also.
ip http secure server
Chetan kumar
Chetan,
The command you're referring to is to enable HTTPS on the router (not SSH).
To enable SSH first look you have a k8 or k9 image.
Please post the output of ''sh ver''
Federico.
Hi Federico
Please try this command with k9 image & let us know the output.
It work for both HTTPS & SSH.
& If any issue let us know .
Chetan kumar
Looks like this doesn't support. Anyway just to disable telnet. I don't really want to have to upgrade
the IOS on the 3 routers since there is always the possibility that it could go south.
SC3640-2#sh ver
IOS (tm) 3600 Software (C3640-IS-M), Version 12.3(9d), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 01-Apr-05 10:15 by dchih
Image text-base: 0x60008B00, data-base: 0x61BB8000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3640-IS-M), Version 12.3(9d), RELEASE SOFTWARE (fc2)
PSC3640-2 uptime is 28 weeks, 20 hours, 49 minutes
System image file is "flash:c3640-is-mz.123-9d.bin"
cisco 3640 (R4700) processor (revision 0x00) with 111616K/19456K bytes of memory.
Processor board ID 28724399
R4700 CPU at 100MHz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
4 FastEthernet/IEEE 802.3 interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Hello DJ,
as Federico has correctly noted in the filename there should some special character to indicate SSH support
in your case the filename is
i
: IP subset (SNMP, IP, Bridging, WAN, Remote Node, Terminal Services)
s: (NAT, IBM, MMP, VPDN/L2F) In 11.3T added VOIP
if there was a k8 or k9 or kn with n>=4 SSH support would be present
Hope to help
Giuseppe
Calin C.
Level 11
Level 11
If you still didn't find a solution you might check this tutorial;
http://www.firstdigest.com/2008/11/cisco-ssh-enable-disable-reconfigure-tutorial/
