CPU utilization high
martin_lx1980
From yesterday night, lots of error informations appear in cisco 7506 and errors pop all the time until now.
%OSPF-5-ADJCHG: Process 1, Nbr x.x.x.x on GigabitEthernet3/48 from LOADING to FULL, Loading Done
%SYS-3-CPUHOG: Task is running for (2680)msecs, more than (2000)msecs (5/4),process = PPP manager.
-Traceback= 4035DA8C 4035220C 403609D0 402BFBA4 41215F44 412E5690 412E5CE8 40B9A9BC 40BA0FCC 40B9CCF0 81D12C08
So i check CPU utilization
TJ_R2#sh process cpu | inc PPP
101 4 143 27 0.00% 0.00% 0.00% 0 PPP auth
103 0 1 0 0.00% 0.00% 0.00% 0 PPPATM Session d
124 16 182 87 0.00% 0.00% 0.00% 0 PPP IP Add Route
134 0 1 0 0.00% 0.00% 0.00% 0 PPP HA
148 4377648 5640964 776 0.00% 11.30% 9.76% 0 PPP manager
197 2492 6512993 0 0.00% 0.00% 0.00% 0 Multilink PPP
230 0 2 0 0.00% 0.00% 0.00% 0 Multilink PPP ou
Does PPP manager cause the issue?How could I do next?
Thanks a lot!
royalblues
Level 10
Level 10
Traceback mostly points to a software issue.
Try upgrading the IOS
Narayan
royalblues
Level 10
Level 10
Narayan
The issue is solved. It is a software bug. When I shut down and no shut down a serial interface, errors disappear.
