CPU UTILIZATION
john.dejesus
Can someone help me on identifying the source of high cpu on my router?
sh ver
Cisco IOS Software, C2600 Software (C2600-ADVIPSERVICESK9-M), Version 12.4(15)T14, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 17-Aug-10 05:40 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
ORIENT16F-2651XM uptime is 3 weeks, 3 days, 11 hours, 38 minutes
System restarted at 10:24:14 PHT Sat May 4 2013
System image file is "flash:c2600-advipservicesk9-mz.124-15.T14.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2651XM (MPC860P) processor (revision 3.1) with 253952K/8192K bytes of memory.
Processor board ID JAD06320NYC
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
2 Serial interfaces
2 Channelized E1/PRI ports
32K bytes of NVRAM.
49152K bytes of processor board System flash (Read/Write)
sh proc cpu sorted 5min | exc 0.00%.*0.00%.*0.00%
CPU utilization for five seconds: 42%/41%; one minute: 38%; five minutes: 40%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  75       41439      4706       8805  0.24%  0.04%  0.38%  66 SSH Process
   5     7792739    408104      19094  0.00%  0.35%  0.32%   0 Check heaps
224     5902215   1109100       5321  0.08%  0.07%  0.23%   0 SNMP ENGINE
222     2049861   2043835       1002  0.00%  0.02%  0.06%   0 IP SNMP
  52     2013004     35764      56285  0.00%  0.06%  0.05%   0 Per-minute Jobs
  71      951889   1869180        509  0.16%  0.02%  0.05%   0 IP Input
   2      346505    423102        818  0.08%  0.03%  0.03%   0 Load Meter
  70      383453  65634637          5  0.08%  0.03%  0.03%   0 IP ARP Retry Age
  33      378768   2115667        179  0.00%  0.03%  0.02%   0 Per-Second Jobs
  67      380424  65634635          5  0.00%  0.02%  0.02%   0 ACCT Periodic Pr
127      180708  21073383          8  0.08%  0.01%  0.00%   0 RBSCP Background
  57       63080   8460880          7  0.08%  0.00%  0.00%   0 e1t1 Framer back
  50       41341    211533        195  0.08%  0.00%  0.00%   0 Net Input
I tried to sort out the cpu processes but the output does not state why it show up a 42% for 5sec interval.
Steve Fuller
Level 9
Level 9
Hi John,
The CPU utilisation you're seeing is traffic related, typically caused by the router CPU doing route lookups for traffic it is forwarding.
Take a read of the forum post understanding show process cpu sorted 1min command as this explains the 5-second CPU utilisation you see i.e., 42%/41%, and what those two numbers mean.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Your 5 second stats shows most of your CPU is being used for "interrupt" processing, which (as Steve) also notes, is CPU used for packet forwarding.  (Remember on software based routers, CPU is used for packet forwarding, i.e. CPU will increase or decrease with the amount of traffic passing through the router.)
A 2651XM is rated at 40 Kpps, which is good for about 10 Mbps (duplex) of minimum sized Ethernet packets (assuming no other services are being used).
