CPU Utilization
medo_shakl
Dears
I need to know if CPU utilization is normal or not as per show command below
Switch Model is 3560
100
 90
 80
 70     *        *
 60     *     *  *          *                     *           *
 50    **     *  *  *     * *   *     *     * *   *     *     *     *    *
 40    **   * ** *  ** *  * *   *     *** * * *  **     *     *     *** **
 30  ****** **** *  ***** * **  *  ********** ** **** * **    ** *********
 20 **********************************************************************
 10 ######################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
                  * = maximum CPU%   # = average CPU%
If you are able to, upgrade the IOS of your switch to 12.2(55)SE9 for better stability.
Leo Laohoo
Post the outputs to the following commands:
  1. sh version;
  2. sh proc cpu | ex 0.00
DC-SW-192-IBM#show version
Cisco IOS Software, C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(40)SE, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 24-Aug-07 01:43 by myl
Image text-base: 0x00003000, data-base: 0x01800000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
DC-SW-192-IBM uptime is 27 weeks, 6 days, 21 hours, 0 minutes
System restarted at 15:33:16 cairo Mon Nov 25 2013
System image file is "flash:/c3560-advipservicesk9-mz.122-40.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3560-24PS (PowerPC405) processor (revision R0) with 122880K/8184K bytes of memory.
Processor board ID FDO1219X1UC
Last reset from power-on
2 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:21:A1:2A:64:00
Motherboard assembly number     : 73-9673-10
Power supply part number        : 341-0029-05
Motherboard serial number       : FDO12190JHH
Power supply serial number      : LIT121509JV
Model revision number           : R0
Motherboard revision number     : A0
Model number                    : WS-C3560-24PS-S
System serial number            : FDO1219X1UC
Top Assembly Part Number        : 800-25861-05
Top Assembly Revision Number    : A0
Version ID                      : V07
CLEI Code Number                : COMUY10ARA
Hardware Board Revision Number  : 0x01
Switch   Ports  Model              SW Version              SW Image
*    1   26     WS-C3560-24PS      12.2(40)SE              C3560-ADVIPSERVICESK
Configuration register is 0xF
CPU utilization for five seconds: 6%/1%; one minute: 6%; five minutes: 6%
 PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
 164    85609058 585472840        146  0.79%  0.42%  0.44%   0 Spanning Tree
jossabor
What you are seeing here is the output for the last 72 hours, the * symbols mean the maximum cpu utilization that it reached during the hour specified, it could be even just a second that it got there, the # symbols mean the average that it had over the full hour, lets take in example hour 5, you see that maximum cpu reached was 70%, however that does not really mean high cpu since the average was 10% which is really common. In the last 72 hours your average was 10%, with some common picks.
