Crashinfo
vishwancc
Level 3
Level 3
Hi ALL:
My router got rebooted and the only thing i have is crash info.
But i am having some problem to find the real cause of the issue could any one help me on this.
Chao
Vishwa
Giuseppe Larosa
Hello Vishwa,
if you have a CCO account with enough rights you can post it in the output intepreter that help you in finding the reasons.
Use a txt file and attach the text file using the browse button.
This RTF file is not good fot that I'm afraid.
Eventually, save a copy of show tech in a text file and if less then 2 MB you can submit it to the tool
Hope to help
Giuseppe
I have tried that and i got next page after sumbit
Internal Server Error
This error indicates that the application is under maintenance. Please check back later.
Although i find that in crash info its says that this is bus error and might be software problem.
Chao
Vishwa
Vishwa
Looking through the crashinfo file these lines are the most significant:
%ALIGN-1-FATAL: Illegal access to a low address
16:28:36 IST Thu Dec 11 2008 addr=0x4B, pc=0x612FF470 , ra=0x67F520D4 , sp=0x706EA858
16:28:36 IST Thu Dec 11 2008: TLB (store) exception, CPU signal 10, PC = 0x612FF470
-------------------------------------------------------------------- Possible software fault. Upon reccurence, please collect crashinfo, "show tech" and contact Cisco Technical Support. --------------------------------------------------------------------
-Traceback= 0x612FF470 0x61304ED8 0x612A7798 0x612B2C48 0x612C32D4 $0 : 00000000, AT : 653E0000, v0 : 000003C0, v1 : 67F51D14 a0 : 00000078, a1 : 00000050, a2 : 00000004, a3 : 70534AF8 t0 : 00000028, t1 : 00000004, t2 : 00000000, t3 : 00000000 t4 : 00000000, t5 : 65870000, t6 : 3400FF01, t7 : 00000001 s0 : 68102934, s1 : 65380000, s2 : 716A9A1C, s3 : 00000000 s4 : 650B0000, s5 : 65940000, s6 : 64480000, s7 : 64480000 t8 : 00000001, t9 : 00000000, k0 : 30408001, k1 : B0020000 gp : 653E6D00, sp : 706EA858, s8 : 65940000, ra : 67F520D4 EPC : 612FF470, ErrorEPC : 9C864000, SREG : 3400FF03 MDLO : FFFFFFF8, MDHI : FFFFFFFF, BadVaddr : 0000004B DATA_START : 0x62ED42E0 Cause 0000000C (Code 0x3): TLB (store) exception
These almost certainly show that there is a problem in your version of software. If this router is covered under a maintenance plan I would suggest that you open a case with Cisco TAC.
Rick
Rick
