CRC and input errors on POS interface
s-durando
I have two Catalyst 6513 with a point-to-point 155Mbps connection between them. Even if I'm not trasmitting traffic between them, I see:
- input errors and CRCs increasing onlt on one side. The number of input errors and CRCs corresponds to the number of BIP(B3) errors in the output of 'show controller pos details'.
- FEBE counter increasing on the other side
These errors seem to be related only to control/signalling traffic. In fact if from one side I ping the other side of the point-to-point link I haven't packet loss, even if I use big sized packets.
I have changed encapsultaion from ppp to the default hdlc but the problem is still present.
Is it an hardware problem?
Stefano
PDC-NGCSPDB-002#sh run int pos1/1/0
Building configuration...
Current configuration : 151 bytes
interface POS1/1/0
description MMC-NGCSMMB-002
bandwidth 155000
ip address 35.220.32.1 255.255.255.252
ip route-cache flow
pos framing sdh
end
MMC-NGCSMMB-002#sh run int pos1/1/0
Current configuration : 166 bytes
interface POS1/1/0
description connessione con PDC-NGCSPD-002
bandwidth 155000
ip address 35.220.32.2 255.255.255.252
ip route-cache flow
pos framing sdh
end
PDC-NGCSPDB-002#sh int pos1/1/0
POS1/1/0 is up, line protocol is up
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
102 packets output, 13521 bytes, 0 underruns
0 output errors, 0 applique, 0 interface resets
0 carrier transitions
PDC-NGCSPDB-002#
PDC-NGCSPDB-002#sh controllers pos det
POS1/1/0
SECTION
LOF = 0 LOS = 0 BIP(B1) = 0
LINE
AIS = 0 RDI = 0 FEBE = 0 BIP(B2) = 0
PATH
AIS = 0 RDI = 0 FEBE = 60 BIP(B3) = 0
PLM = 0 UNEQ = 0 TIM = 0 TIU = 0
LOP = 0 NEWPTR = 0 PSE = 0 NSE = 0
MMC-NGCSMMB-002#sh int pos1/1/0
404 input errors, 404 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1407 packets output, 217990 bytes, 0 underruns
MMC-NGCSMMB-002#sh controllers pos det
POS1/1/0
SECTION
LINE
PATH
AIS = 0 RDI = 0 FEBE = 0 BIP(B3) = 402
beth-martin
Level 5
Level 5
Ensure that both router ends of a POS link use the same CRC. Mismatched CRC settings are one configuration parameter to check when a POS interface stays up/down. Use the show interface command to confirm your settings. All Cisco POS interfaces support CRC-32. Higher-rate interfaces use CRC-32 as the default
glbeach
B3 errors when seen by themselves are almost always a provider issue.  When we troubleshoot POS Bit errors we narrow down the offending device by checking device to device in the path and finding the devices that show B2 and B1 errors.  If we see B1 errors the problem link is local.B3 errors when displayed by themselves represent a path error. From your controllers you appear to have a one way Path issue in the path toward MMC-NGCSMMB-002#.
Reference: http://www.cisco.com/en/US/tech/tk482/tk607/technologies_tech_note09186a0080094a79.shtml
See "when do partucilar BIP errors occur"
