CRC Error found in C2500 router.
Amit Thakkar
Dear All,
We are monitoring everyday C-2500 router, the CRC and input error are  increasing day by day.This are current readings as observed on 18 Feb.
Any Over-come from this please guide us....
C-2500-R1#sh int s0
Serial0 is up, line protocol is up
  Hardware is HD64570
  Internet address is 192.168.XX.XX/30
  MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
     reliability 255/255, txload 8/255, rxload 55/255
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:16, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1w1d
  Queueing strategy: fifo
  Output queue 0/40, 577878 drops; input queue 0/75, 29 drops
  5 minute input rate 449000 bits/sec, 907 packets/sec
  5 minute output rate 68000 bits/sec, 5 packets/sec
     31866633 packets input, 692108732 bytes, 29 no buffer
     Received 89258 broadcasts, 0 runts, 0 giants, 0 throttles
1236 input errors, 818 CRC, 80 frame, 209 overrun, 209 ignored, 250 abort
     28696315 packets output, 1815650600 bytes, 0 underruns
     0 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
Readings as observed on 16 Feb
  Hardware is HD64570
  Last input 00:00:01, output 00:00:00, output hang never
  Last clearing of "show interface" counters 6d12h
  Output queue 0/40, 393330 drops; input queue 0/75, 17 drops
  5 minute input rate 0 bits/sec, 1 packets/sec
  5 minute output rate 3000 bits/sec, 2 packets/sec
     21345337 packets input, 2268645157 bytes, 17 no buffer
     Received 65239 broadcasts, 0 runts, 0 giants, 0 throttles
    513 input errors, 487 CRC, 40 frame, 13 overrun, 13 ignored, 138 abort
     19249627 packets output, 1931191630 bytes, 0 underruns
Readings as observed on 15 Feb.
  Hardware is HD64570
  reliability 255/255, txload 60/255, rxload 17/255
  Last input 00:00:02, output 00:00:00, output hang never
  Last clearing of "show interface" counters 5d16h
  Output queue 0/40, 353430 drops; input queue 0/75, 17 drops
  5 minute input rate 137000 bits/sec, 81 packets/sec
  5 minute output rate 487000 bits/sec, 76 packets/sec
  19088829 packets input, 1751500313 bytes, 17 no buffer
  Received 57112 broadcasts, 0 runts, 0 giants, 0 throttles
  83 input errors, 59 CRC, 0 frame, 12 overrun, 12 ignored, 10 abort
  16955726 packets output, 4261324851 bytes, 0 underruns
paolo bevilacqua
Complain to the telco.
