CRC Error
cindylee27
My users saying that the network is slow.
Below is the WAN interface captured:
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 255/255, txload 2/255, rxload 1/255
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 10w5d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 245
Queueing strategy: weighted fair
Output queue: 0/1000/64/244 (size/max total/threshold/drops)
Conversations 0/36/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
5 minute input rate 3000 bits/sec, 2 packets/sec
5 minute output rate 16000 bits/sec, 2 packets/sec
9682134 packets input, 1710441763 bytes, 0 no buffer
Received 764714 broadcasts, 0 runts, 0 giants, 0 throttles
8456 input errors, 8456 CRC, 2799 frame, 500 overrun, 0 ignored, 3444 abort
10229243 packets output, 3657182173 bytes, 0 underruns
0 output errors, 0 collisions, 372 interface resets
2 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
How can i resolve this issue?
Its time for you to get the physical link checked by availing loop from your local telco..
Most of the times it will solve or help you to find out whether you have any error in your link..
regds
6 Replies 6
spremkumar
Level 9
Level 9
Can you try clearing up the counters or this interface and check ?
As per the stats the counters has been cleared before some 10 Weeks 5 Days.
Use clear counters and specify the interface where you are seeing this errors..
regds
Sprem,
Thanks for you reply.
I have tried clear int s0/0.
But the CRC error is still there. How can i reset the CRC error to be 0?
Thanks!
cindy
regds
Thanks Sprem!
I will try to do as per your advise. :D
shahzad-ali
Reset counter on the WAN interface to get the fresh numbers to troubleshoot. "" Last clearing of "show interface" counters 10w5d ""
opssssss too late :)
