create new valn
mahir1234567892
i have tow core switch cisco 4500 i need to create new vlan no.8, can't able to create this vlan, see below message in core switch 1.
 (Core-1(config)#vlan 8
VTP VLAN configuration not allowed when device is not the primary server for vlan database.)
core switch 2.
Core-2(config)#vlan 8
VTP VLAN configuration not allowed when device is in CLIENT mode.
how to fixed this issue
thankyou
Julio E. Moisa
About Core-2 The reason is because your device is configured as vtp client mode, you can create vlans on the devices configured as the vtp server or transparent mode.
You should verify who is your device with vtp server mode and create the vlan 8 there, it will propagate the vlan to the client devices.
About Core-1, you probably are using vtp version 3, and this devices is not configured as primary server for vtp. Other device could be configured as server on your network. It should be verified first.
Please check this link for more info about vtp version 3: http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/solution_guide_c78_508010.html
https://networklessons.com/switching/vtp-version-3/
Also you can run: show vtp status to know the mode used on the device.
 Hope it is useful :-)
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi  Julio Moisa,
see below VTP status in core 1 and core 2
Core-1#sh vtp status
VTP Version capable : 1 to 3
VTP version running : 3
VTP Domain Name : MAHIR-MED
VTP Pruning Mode : Enabled
VTP Traps Generation : Enabled
Device ID : f0f7.553a.cf80
Feature VLAN:
VTP Operating Mode : Server
Number of existing VLANs : 129
Number of existing extended VLANs : 499
Maximum VLANs supported locally : 4094
Configuration Revision : 556
Primary ID : f0f7.553a.cf80
Primary Description : AQEEQ-B1-Core-1
MD5 digest : 0x7F 0xA1 0x18 0x9B 0x7B 0xE9 0x3C 0x95
0xA8 0x55 0x2D 0xD2 0xB3 0x43 0x88 0x4C
Feature MST:
VTP Operating Mode : Transparent
Feature UNKNOWN:
core2
Core-2#sh vtp status
Device ID : f0f7.553a.cd40
Feature VLAN:
VTP Operating Mode : Client
Feature MST:
Feature UNKNOWN:
Hello guys,
please help me regarding above issue.
Apologies for the late response, please let me verify your config. Just a question, is it a new vtp implementation on your devices? you could configure the following command on your vtp server device (Core-1):
switch# vtp primary  (force is optional but you can use it if you want to force to take this role, try first with vtp primary only)
switch# vtp primary vlan   (note: not over configure terminal)
Please double check first how your network has been working in order to avoid any inconvenience. You have to be cautious with vtp, remember have backups of your configurations.
