Creating a time-based ACL
saqibmoghul1
Hi all,
I need to create a time-based ACL. I have been told that I just need to create the time-range and delete the existing access-list 199.
The rest of the config is already there as a nested policy map, so you will not need to apply anything to the interface.
Here is the policy map and class map:
class-map match-any MANCAM
match access-group 199
policy-map WAN-OUT
class MANCAM
  police cir 256000
interface Serial0/0/0:1.1 point-to-point
service-policy output WAN-OUT
Can someone help?
2 Accepted Solutions
John Blakley
A time range needs to be created an applied:
time-range MANCAM
periodic weekdays 08:00 to 17:00
ip access-list ext 199
no
permit tcp any any eq 80 time-range MANCAM
deny tcp any any eq 80
When the time range is in effect, Monday - Friday from 8 - 5PM, traffic to a web server will be allowed. If the time is outside of this range, the acl entry is bypassed and hits the second line to deny traffic to the web server. The same concept applies for policy maps as well. If the traffic is within the time range, the traffic is policed/shaped/dropped (whatever your policy does), and if it's outside of the range then it's would end up matching class default (or another class if you wanted ).
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
If you have an existing acl you'll want to remove it before adding this one. Remember to add it in the correct sequence in your acl though.
John Blakley
time-range MANCAM
no
HTH,
John
Ah ok. Thank you so much for assisting.
What is the 'no' line for ?
Ah yes. Excellent.
Will do.
Thank you so much John. I get it now!
