Creating DMZ
imanco671
Level 5
Level 5
Hello Community,
creating a DMZ on a ASA 5510 router within my environment of 3 internal subnets who have thier own firewall.
I have ethernet0/0 assigned a WAN address
I have ethernet0/1 assigned a subnet 192.168.201.0
I need to add ethernet0/2 a subnet 192.168.202.0
1. Ethernet0/1 will be the DMZ. which should not connect to my internal network.
2. Ethernet0/2 will be a new internal network and should be connected to my 3 other internal subnets via internal router.
3. I have to regulate traffic between ethernet0/1 and ethernet0/2, deny everything and open ports for needed communication between the two.
how will my other networks reach my DMZ and vise versa?
I have attched a screen shot of my network.
2 Accepted Solutions
Jon Marshall
John
On your internal router you would have route for the DMZ ie.
ip route 192.168.201.0 255.255.255.0 192.168.202.x  <-- where .x is the internal IP of the ASA firewall.
As for setting up access as far as NAT goes if you want the DMZ to be able to initiate connections to the inside and the inside to the DMZ for all 3 networks then on the ASA -
static (inside,dmz1) 192.168.201.0 192.168.201.0 netmask 255.255.255.0
static (inside,dmz1) 10.10.10.0 10.10.10.0 netmask 255.255.255.0
static (inside,dmz1) 192.168.200.0 192.168.200.0 netmask 255.255.255.0
note the above is per 8.3 NAT code. If your ASA is running 8.3 or greater the NAT will be different.
Edit - i forgot. On your ASA you will need to add routes for the 10.x.x.x and 192.168.200.x network ie.
route inside 10.10.10.0 255.255.255.0 192.168.201.x  <-- where x is the IP assigned to the router interface on the 192.168.201.x network
route inside 192.168.200.0 255.255.255.0 192.168.201.x
Jon
Jon has given you pretty much the whole config . Ideally in the DMZ's(public) you dont't want the servers initiating connections to internal network. The connection's should be initiated from internal to the DMZ. This is for security pruposes.
There is a very good resource which pretty much every Architects/Designers use which is
www.cisco.com/go/cvd    (This is an area where you find the Cisco recommended design guides for every scenario)
HTH.
please rate if helpful
Jon Marshall
John
Jon
HTH.
