Creating Smart licence with http destination
okochat18
Hi Community,
Iam creating Smart license in IOSXR with http
So I used "destination transport-method http" and also put the destination url.
When I do show run, i see "destination transport-method email disable" also in the configuration
call-home
service active
contact smart-licensing
profile CiscoTAC-1
active
destination address http https://xxxxxx
What does this command do?
Is there need to remove it from the settings?
2 Accepted Solutions
M02@rt37
Hello @okochat18
The comand destination transport-method email disable within the call j
home config specifically instructs the device to disable the email transport method for call home notifications/reports.
When configuring smart licensing with HTTP transport method (using destination transport-method http), it is common practice to disable unnecessary transport methods to streamline the configuration and reduce potential overhead.
Disabling the email transport method ensures that the device does not attempt to send call home notif via email.
https://www.cisco.com/c/en/us/td/docs/switches/lan/smart_call_home/SCH22/SCH22_Ch2.html#wp1038641
Best regards
@okochat18
This command is already disable.
Let this command in disable under call-hone configuration.
Best regards
5 Replies 5
M02@rt37
Hello @okochat18
Best regards
okochat18
Thanks for your quick response.
If I remove the command with the following, would it have effect on anything?
no destination transport-method email disable
@okochat18
Best regards
okochat18
M02@rt37 Thanks.
You're welcome @okochat18
Best regards
