critical sys log on router - IPSEC vpn
alanc3141592654
Hey Guys,
I keep getting the below system on one of our wan routers that terminates a vpn tunnel.
Aug 19 11:29:13.553 AEST: %VPN_HW-1-PACKET_ERROR: slot: 0 Packet Encryption/Decryption error, Output Authentication error:srcadr=x.x.x.x,dstadr=x.x.x.x,size=1376,handle=0x58E9
we have 1841 with ios version 12.4(13r)T
I found the 2 cisco bugs,
- CSCee43714
- CSCeg52468
But our ios does not seem to be affected.
I've also checked the security-Association information which is the same on both routers.
Does anyone have any ideas or suggestions?
Alan
gmarogi
Level 5
Level 5
This is a notification message seen on the console of the decrypting peer that tells the user that IPSec packets have been received out of order.
I think 'Output Authentication' may be indicating ICV value mismatch and packet corruption.
Verify the cause of the problem by disabling the cef switching by issuing these commands:
(conf)# no ip cef
(conf-if)# no ip route-cache
(conf-if# no ip mroute-cache
For a workaround, issue these commands:
Change tcp adjust-mss on interfaces
Change crypto ipsec df-bit
