Cross Connect between Router and Switch
duke
  HI
I have Two Router ( A,B) and Two Switch (C,D) and Two Firewall ( E,F). ALl the ISP are connect to my Router.
Between router running HSRP.  At present sceniro : Router A , B connect to Switch C,D  ( A-C, B-D) and From Switch ( C,D) connect to Firewall ( E,F).
Now my plan also connectivity from router A to Switch C and D  ( A-C,D) and From Router B connect to Switch C and D ( B-C,D). Same From Switch to Firewall.
If i go this sceniro then get any advantage or its not standard. If Standard then How I configure in Router and Switch ???
Please Help by your Exprience.
Khan
rais
Level 7
Level 7
It depends upon what you are trying to achive, but standard practice is the first topology you have mentioned.
HTH.
