Cross VLAN traffic issue
davidltp80
I am having trouble getting my dev environment working properly. I am unable to get my ESXi server to communicate with my Windows Server on a separate VLAN. From the diagram below I want DLESXi2 to route via DEVDLSRV1 (on DLESXi1).
I have tried assigning ip addresses to the vlan's, adding helper addresses, adding a static route to the 192.168.17.0/24, and also added vlan tag 17 to DLESXi2. All did not allow communication from the 17 network to DEVDLSRV1. Maybe I'm making this too complicated, but I would like for my server (DEVDLSRV1) to be the DHCP/DNS server and for all communication to the "Internet" (and also the Public_Network which is my business domain) to go through this server (This last part is not part of this forum).
Switch: Cisco 3550Network Diagram
My config file is as such:
no aaa new-model
ip subnet-zero
ip routing
ip name-server 192.168.3.237
ip name-server 192.168.3.238
vtp mode transparent
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 3
 name Public_Network
vlan 17
 name Private_Network_17
interface FastEthernet0/1
 switchport access vlan 3
 switchport trunk allowed vlan 3
 switchport mode access
 duplex full
 spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
 switchport trunk allowed vlan 3,17
interface FastEthernet0/13
 switchport access vlan 17
interface Vlan1
 no ip address
 shutdown
interface Vlan3
 no ip address
interface Vlan17
 no ip address
ip default-gateway 192.168.3.252
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.3.252
ip http server
Any help would be extremely appreciated.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You don't have IPs on any of your VLAN interfaces.(?)
I tried that before and the most I got was pinging to VLAN 17's ip address, nothing more.
I setup VLAN 3 with IP: 192.168.3.223/24
VLAN 17 with IP: 192.168.17.254/24
and still nothing.
Disclaimer
Posting
To route, the router will need interface IPs.
Normally, you hosts will have the router's IP at their gateway.  Do they?
mahdymohamed
 switchport mode access <<<<<<<< I believe this should be Trunk mode
And in the trunk allow only 3,17
Hope you try this and reply with the result
