CRYPTO-4-RECVD_PKT_INV_SPI causing outage between connections
Gambo8807
CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=x.x.x.10, prot=50, spi=0x12C68E18(315002392), srcaddr=x.x.x.9, input interface=GigabitEthernet0/0/5
Hello all,
This is the error we are currently battling. The link this issue is happing on is GigabitEthernet0/0/3. We have been trying to resolve this for some time now with no luck. When this happens, this problem is resolved by doing a "shut, not shut" on GigabitEthernet0/0/3, which fixes it immediately however, it occurs every 8-12 hours. We have tried the SPI recovery command, and it is still persistent.
Things to note:
All configurations on both of the routers match (for IPSEC)
All timers match
We are using static routes for the entire network (requirement)
Dan Frey
Do you have isakmp keepalives or DPD turned on?
Hello Dan,
Running through the commands I am not seeing this enabled, is this something that we have isakmp profiles to enable? Or is this a global command that we are able to use? Currently, we are not using profiles.
Thank you for the help, I really appreciate it.
 If  you are using isakmp commands then you are using IKEv1 and this can be deployed from global config "crypto isakmp keepalive 10 2".  I would start by turning on keepalives and see if the problem persists or not.   place this command on each device that is running ikev1/ipsec.
Thanks for the info Dan,
We tried that this morning and unfortunately, that did not resolve the issue at hand.
