IBGP Routes
janm0a1
I have some
IBgp
routes on my route table with no ASN number.
Will these routes be permanent?
Will they ever timeout?
My thinking is that these routes will not remain after a period of time, is that correct?
2 Accepted Solutions
M02@rt37
Hello @janm0a1,
iBGP (internal BGP), routes
exchanged between routers within the same autonomous system (AS) don't typically carry AS numbers in their route entries. This is because
iBGP routers
share routes within the same AS, and the AS number remains constant within the AS.
iBGP routes
, once learned, are not subject to a default timeout. Unlike some other routing protocols,
iBGP routes
don't have a built-in mechanism to expire after a certain period of time. These routes will remain in the routing table until there's a change in the network topology or configuration that causes the route to be withdrawn.
iBGP routes
will persist as long as the routes themselves are being advertised by the advertising router and the receiving router continues to consider them valid. If there's a change in the network, such as a link failure or a configuration change that affects the BGP advertisements, the routes may be withdrawn and updated in the routing table accordingly.
Best regards
Great thanks for the info!
5 Replies 5
No. If they are in your BGP table and unless you have a policy configured to remove them then they will remain there. When
iBGP
neighbors exchange updates they don't utilize the
AS path
because the loop prevention mechanism would not allow it. YOu have 2 BGP neighbor types:
eBGP
- Their loop prevention mechanism is
AS path
(dont accept routes with its own AS in the PATH). eBGP neighbors advertise their
AS path.
iBGP ->iBGP
- Their loop prevention mechanism is dont advertise
 iBGP
learned routes to
iBGP
neighbors. You can modify this behavior with rout-reflectors. If they also relied on
AS path
then that would be another obstacle. For that reason you wont see
iBGP
learned routes with an AS the same as their own because its internal and no need.
-David
Giuseppe Larosa
Hello @janm0a1 ,
>> I have some
IBgp
This is normal , they are routes that are originated within your AS.
Before advertising to a true eBGP peer the local AS is appended to the routes and they can be advertised, in
iBGP
the local AS is not added to the
AS path
as it is the same for all
iBGP
peers and it would not provide any protection from routing loops.
This is also the reason why the
iBGP
  requires a full mesh of
iBGP
sessions unless BGP route reflectors or BGP confederations ( or both in a great ISP ) are used.
The BGP RR servers are allowed to reflect = propagate routes between their clients (
iBGP
peers defined as clients on RRS BGP config)
the safe reflection is performed by adding two BGP attributes to the
prefix:
BGP Originator ID =  BGP Router ID of the iBGP peer that originated the prefix
cluster list =  list of reflections it contains either the RRS BGP Router-id of the cluster -id if configured.
A shorter cluster list is preferred when choicing the best path.
Both are used to avoid issues , if a route cluster list contains the local
cluster-id
it is not propagated to the clients as it has been originated by one of them.
if a router would receive a route with
Originator ID
equal to its BGP router id it would not install it.
BGP confederations work by using mini ASes taken from the private AS space 64512 - 65535, but the configuration needs to be changed on all routers. BGP RR are more used for this reason as their introduction requires changes only on RRS.
RRS need to be fully meshed between them as.
No, this is not correct these routes are normal
prefixes originated within your AS this is why the AS path
attribute is still empty as I have written above before advertising to an external eBGP peers the local AS is appended on the left in the
AS path
attribute so from the point of view of a direct eBGP peer those routes have
AS path =  your ASN
Hope to help
Giuseppe
Good Information thanks!
M02@rt37
Hello @janm0a1,
iBGP routers
iBGP routes
iBGP routes
iBGP routes
Best regards
